Dumb question about brushes!
jpwic
Depends on what you want to paint <_< I tend to use a number 3 or 4 brush to coat entire space marine models, then number 1, 0, 00 and/or 000 ones for the details, depending on how small they are.
Washes don't need special brushes. In fact, nothing needs a special brush — it's just that you'll probably don't want to do much drybrushing with an expensive, good brush :lol:
Sizes can vary between manufacturers. A brush marked as #1 from one company could be the same as a #4 from a different company or a #00 from another.
That said, I like to use Liner brushes because they have longer bristles and (the ones I get) have shorter, thicker handles -- but that last part is entirely personal taste and preference. These are what I used for eyeliner and (rarely) lipliner for years. I hate pencils and those short, hard brushes the cosmetic makers tend to push. So like I said ... personal choice held over from a different hobby <_<
In general, I like to use a brush about the same size as GW's "fine detail" brush with 2-3mm long bristles for most of my painting. I do base coats with GW starter brushes and very fine detail like eyes with Loew-Cornell 18/0 fine liner. I have a few other brushes like a GW tank brush I have abused for years for dry brushing, a couple of oval mop brushes for vehicles and terrain (again ... old makeup brushes), and things like that. All in all, the one I have in hand the majority of the time is Loew-Cronell's 7000 series #2 liner.
If you're asking this question, I'm assuming you're new to the hobby. And if you're new to the hobby, I would suggest the following:
GW Standard Brush
GW Detail Brush
GW Medium Drybrush
That should be enough. If you're paint isn't too thick, you can paint the smallest of details with a regular detail brush, or even a standard brush. Just make sure to take care of the point.
-CH
There are no dumb questions, we've all started off sometime :angry:
This might be quite a useful article - here - explains what to look for in a new brush, how to look after them once you've bought them, and why you should never wash your brushes in hot water.
I like the L/C 10/0 liner, 0 is large enough for basecoats, and 2/0 is fine for smaller stuff... Having just bought a couple of Windsor and Newton Series 7 (size 0 and 00) I can say that they are definately worth it but I call that a high end brush and shouldnt be used by a new painter until brush care has been learned.
GW Standard Brush
GW Detail Brush
GW Medium Drybrush
-CH
Going to Games Day this year and painting a mini at the paint and take table I can catagoricly say DO NOT USE GW BRUSHES FOR ANYTHING!! They would be okay for little Timmy 12 year old but if you want any kind of quality on your paintjob, do not use. I am a veteran painter, It was the first round of the paint and take, brand new GW brushes and they would not hold a point at all.
That's a bit strong I think. I've painted my entire hellbrute using only the GW standard brush, and it's still like new (I'll have to finish it though before y'all can decided if it's "quality" or not :( .) Definitely not the best brushes, but they have their uses.
-CH
