Olgerth Istaarn Posted September 6, 2012 Share Posted September 6, 2012 I'm thinking of picking up a few Dark Vengeance bits from eBay and bit sellers. However I see that the Librarian has the obnoxious winged sword on his chest piece, the limited edition chaplain has an equally obnoxious winged sword on his cloak, and all tactical marines have them on shoulder pads. What's the best way to gently scrape these off without ruining the underlying surface too much? Especially on the cloaks and other cloth pieces. Link to comment https://bolterandchainsword.com/topic/260303-best-way-to-gently-scrape-off-embossed-emblems/ Share on other sites More sharing options...
Grotsmasha Posted September 6, 2012 Share Posted September 6, 2012 For the cloth, it's going to be difficult, but my suggestion is to use the flat of your blade and slowly scrape away the defined edges, as these are what really define the shape. Once the edges have been smoothed as much as possible, you may find that the emblems won't stick out like a sore thumb. Cheers, Jono Link to comment https://bolterandchainsword.com/topic/260303-best-way-to-gently-scrape-off-embossed-emblems/#findComment-3167673 Share on other sites More sharing options...
chromedog Posted September 6, 2012 Share Posted September 6, 2012 Acetone. Soak the entire model in it for several weeks. The goo will eventually not have any DA iconography on it. Otherwise, if the sight of DA iconography offends thine eyes, DON'T BUY THE STUFF. I'd use extreme care, a sharp blade (and my mail glove - got it from a butcher mate) and carefully shave them back. Then bog the gaps with putty. Then, after realising that assembling some DA veterans and regular Tac marines would be cheaper, quicker, and much more satisfying, dump them all into the bucket of acetone and start again with those. Link to comment https://bolterandchainsword.com/topic/260303-best-way-to-gently-scrape-off-embossed-emblems/#findComment-3167779 Share on other sites More sharing options...
Chaplain Hiltraud Posted September 6, 2012 Share Posted September 6, 2012 Personally, I think the Dark Vengence models will be too hard to scrape away insignia without damaging the model (or yourself!!) That being said though, they are fantastic looking models and I can understand why you would like to convert them to your own liking... My technique (as previously mentioned) is to use a fresh and sharp hobby knife and gently slice and scrape away the offending insignia, it's a little dangerous due to the slip factor but it'll get the job done, use some GS or LGS and a file/s to clean up. Generally I glue or sculpt my own insignia afterwards. Search "Dark Vengence [Librarian] Conversion" and you'll see how other people have converted the models, you might get lucky with a tutorial :lol: Yours in Honour, Faith and Blood, Chaplain Hiltraud Link to comment https://bolterandchainsword.com/topic/260303-best-way-to-gently-scrape-off-embossed-emblems/#findComment-3167943 Share on other sites More sharing options...
ShinyRhino Posted September 6, 2012 Share Posted September 6, 2012 If you're dead set on doing this, get some Testor's modelling sandpaper. It comes in a pack with a variety of grits. Then get a kabob skewer or a drinks stirrer. Cut small strips of sandpaper and superglue them around the skewer/stirrer to make a "sanding stick." It can be used to more finely remove detail after you've carved as much as possible away with your hobby knife. Link to comment https://bolterandchainsword.com/topic/260303-best-way-to-gently-scrape-off-embossed-emblems/#findComment-3168022 Share on other sites More sharing options...
The Angelus Sanctus Posted September 6, 2012 Share Posted September 6, 2012 Please make sure you keep your posts constructive and positive guys. There shouldn't be any need to go off topic with feedback on how best to perform what the OP has asked for. Link to comment https://bolterandchainsword.com/topic/260303-best-way-to-gently-scrape-off-embossed-emblems/#findComment-3168129 Share on other sites More sharing options...
FashaTheDog Posted September 6, 2012 Share Posted September 6, 2012 Dremels are your best friend for this kind of work. It will take a steady hand, a low speed, the proper bit, and some practice, but I have already appraised my set for conversion potential and I feel quite confident that with a conical grinding bit, I could remove every last trace of unwanted detail so the Dark Angels could belong to any Loyalist Chapter or Traitor Legion/Warband and not ruin the model. Link to comment https://bolterandchainsword.com/topic/260303-best-way-to-gently-scrape-off-embossed-emblems/#findComment-3168277 Share on other sites More sharing options...
Olgerth Istaarn Posted September 6, 2012 Author Share Posted September 6, 2012 I love dual-purpose threads: they provide good advice and demonstrate without a doubt who the Village Idiot of the Day is. Bravo, thread! Thanks for all the pointers. I just might try the dremel. I read somewhere that glue can be used to dissolve mold lines (and potentially unwanted detail). Anyone have experience with that? Link to comment https://bolterandchainsword.com/topic/260303-best-way-to-gently-scrape-off-embossed-emblems/#findComment-3168565 Share on other sites More sharing options...
ShinyRhino Posted September 7, 2012 Share Posted September 7, 2012 Thanks for all the pointers. I just might try the dremel. I read somewhere that glue can be used to dissolve mold lines (and potentially unwanted detail). Anyone have experience with that? It can be done, but it requires a thin, "hot" liquid cement. Hot means it melts plastic almost instantly, leaving little glue residue behind. It's used more by fine scale modellers and mecha builders. Standard Testor's plastic cement won't cut it. You'll justend up with blobs of plastic cement everywhere. Be careful with the Dremel technique. One slip and you've likely ruined the model. Link to comment https://bolterandchainsword.com/topic/260303-best-way-to-gently-scrape-off-embossed-emblems/#findComment-3169393 Share on other sites More sharing options...
UltraRich Posted September 7, 2012 Share Posted September 7, 2012 Evening I did a load of work to the Space Hulk Terminators to make them suit my Ultra army. Some of their iconography was really prominent. The above posters have got it right (mostly!) For the flat/plate areas use a knife and then very high grit wet and dry sand paper. If this leaves a rough surface make a GS wash with liquid GS and water. For the cloth scrape off what you can and then use rolled up wet and dry (or the scewer option - I must try this) to get in the folds. If you mess up either use GS or liquid GS wash to smooth it. The thing to remember is you are cutting back so you cant mess up as you can rebuild. Just take your time. Ive got a Libby on the way so I'll up mine once its cleaned up Link to comment https://bolterandchainsword.com/topic/260303-best-way-to-gently-scrape-off-embossed-emblems/#findComment-3169467 Share on other sites More sharing options...
Montuhotep Posted September 7, 2012 Share Posted September 7, 2012 UltraRich has the best method on balance, I'd say - no reason to go fast over a thing like this and the sandpaper will still leave a lot of cloak behind at a decent thickness, potentially chopping through the cloak is a danger. In the same vein, don't whatever you do use a metal bit for grinding with a Dremel - the friction between metal and plastic will melt the plastic completely and cause it to 'ball' around the grinder, leaving some really nasty marks, potentially holes, a fouled up grinder and one Hell of a bad smell. I know this. :P Link to comment https://bolterandchainsword.com/topic/260303-best-way-to-gently-scrape-off-embossed-emblems/#findComment-3169585 Share on other sites More sharing options...
FashaTheDog Posted September 8, 2012 Share Posted September 8, 2012 Paladin, that bad smell is the microscopic particles entering your lungs and adhering to the interior. Link to comment https://bolterandchainsword.com/topic/260303-best-way-to-gently-scrape-off-embossed-emblems/#findComment-3169898 Share on other sites More sharing options...
UpTheIron Posted September 8, 2012 Share Posted September 8, 2012 Great thread, confirmed that the method i was thinking of would work. Im going in reverse though, Space Hulk BA into Dark Angels :confused: Link to comment https://bolterandchainsword.com/topic/260303-best-way-to-gently-scrape-off-embossed-emblems/#findComment-3170036 Share on other sites More sharing options...
JeffJedi Posted September 11, 2012 Share Posted September 11, 2012 Even as a Dark Angels I've had to remove something and it's really quite easy. I removed the Tactical Arrow from the shoulder pad so that I can use a few as Bolter Devastators. You just scrape off the symbol with your knife and use needle files to smooth out the surface. Link to comment https://bolterandchainsword.com/topic/260303-best-way-to-gently-scrape-off-embossed-emblems/#findComment-3173031 Share on other sites More sharing options...
appiah4 Posted September 12, 2012 Share Posted September 12, 2012 Acetone. Soak the entire model in it for several weeks. The goo will eventually not have any DA iconography on it. Otherwise, if the sight of DA iconography offends thine eyes, DON'T BUY THE STUFF. I'd use extreme care, a sharp blade (and my mail glove - got it from a butcher mate) and carefully shave them back. Then bog the gaps with putty. Then, after realising that assembling some DA veterans and regular Tac marines would be cheaper, quicker, and much more satisfying, dump them all into the bucket of acetone and start again with those. You realize that 10 DV marines go for 10 quids and a Tactical Squad goes for 25 right? I'll take the satisfaction of having satisfactorily converted the DV models to getting shafted by GW anytime. I hope I can score some AOBR terminators before they go OOP.. Dremels are your best friend for this kind of work. It will take a steady hand, a low speed, the proper bit, and some practice, but I have already appraised my set for conversion potential and I feel quite confident that with a conical grinding bit, I could remove every last trace of unwanted detail so the Dark Angels could belong to any Loyalist Chapter or Traitor Legion/Warband and not ruin the model. I happen to own a dremel but never used it for this. I also happen to own over 200 bits for it. Which 'bits' would you recommend for sanding down chapter iconography on plastic and metal models? Link to comment https://bolterandchainsword.com/topic/260303-best-way-to-gently-scrape-off-embossed-emblems/#findComment-3173630 Share on other sites More sharing options...
Bungicats Posted September 12, 2012 Share Posted September 12, 2012 I use a very honed diamond bit quite narrow and on low speed lest thee wants to also remove fingers. Never hold the stupid thing in a spot for more than a sec rather keep your touch light and gently go back and forth. I always tidy up with knife or needle files afterwards! Link to comment https://bolterandchainsword.com/topic/260303-best-way-to-gently-scrape-off-embossed-emblems/#findComment-3173743 Share on other sites More sharing options...
lhg033 Posted September 12, 2012 Share Posted September 12, 2012 i removed the tactical markings on a couple of aobr marines with a knife and needle file set - i think hard armour is going ot be easier to cover up mistakes than cloth areas. another option is grinding down the full shoulder pads and putting standard blank ones in their place on the tacticals. cloaks (chaplain mainly) - you could turn these into fur cloaks with a bit of green stuff. not sure it'd look so good to have fur on the tabards as well :S. aobr stuff, and the box set are still available at several bits sites and independant stores. Link to comment https://bolterandchainsword.com/topic/260303-best-way-to-gently-scrape-off-embossed-emblems/#findComment-3173776 Share on other sites More sharing options...
