TMK0377 Posted September 8, 2012 Share Posted September 8, 2012 Does anyone have a good way to paint green robes? I have the regular bleach bone cloth robes down pat, but does anyone have a recipe for dark green robes that does not look just like DA power armor? Thanks! Link to comment Share on other sites More sharing options...
Artemid Posted September 8, 2012 Share Posted September 8, 2012 Robes generally, I think, give more room to play with shades than power armor does. You can start with a darker base color and work up more levels of highlighting than you might on Power Armor. What are you painting dark green robes over? Termies? Link to comment Share on other sites More sharing options...
TMK0377 Posted September 9, 2012 Author Share Posted September 9, 2012 Yes I want to paint green robes over termies and an interrogator Chaplain in Terminator armor Link to comment Share on other sites More sharing options...
JeffJedi Posted September 9, 2012 Share Posted September 9, 2012 I'd say green robes should end up brighter than power armor. Also where power armor has sharp thin highlights, the robes should have larger areas of the lighter color. I want to ask what colors are best for secondary robes. The new HQs from the Dark Vengeance set wear more than one layer. I'm not crazy about the purple color, but if nothing is better I'll use it. Link to comment Share on other sites More sharing options...
TMK0377 Posted September 9, 2012 Author Share Posted September 9, 2012 Jeffjedi, I think that crimson red robes would look good, although I would keep it dark to avoid Xmas marines lol. Link to comment Share on other sites More sharing options...
Grotsmasha Posted September 9, 2012 Share Posted September 9, 2012 For my green robes I use (old colours still) DA Green Base, Snot Green 1st Layer. 1- DA green over black 2- Nuln oil 3- DA green over all but the deepest recesses 4- Watered down Snot Green (REALLY watered down, 2 parts water to 1 part paint) over the most prominent high spots. Over 5-7 layers you want to start fairly broadly and with each successive pass, tighten it up. This will give you a very gradual colour change which suits cloth. This method is what I used on my DV Ravenwing Librarian, both the green and purple. Cheers, Jono Link to comment Share on other sites More sharing options...
Garath Posted September 9, 2012 Share Posted September 9, 2012 Might wanna try using DA green with any "milky" type lighter colour for blending. The ones I'm reffering too are: Bleached bone, Graveyard Earth (continued with Skull white) , Rotting Flesh, Pallid Flesh ...blend those and add Skull white for the say 3 last layers.... Link to comment Share on other sites More sharing options...
Gillyfish Posted September 9, 2012 Share Posted September 9, 2012 I try to keep the robes generally dark and use more gradual highlights than for armour. I start with a black/DA green mix, highlight with DA green, then DA green with snot green, increasing the latter with each highlight. Keep the paint relatively thin. I like to give the impression that the robes are made of heavy material that doesn't reflect the light all that much, so the tones are there, but not as much as if I were to try and paint silk, for example. Hope that helps. Link to comment Share on other sites More sharing options...
RayJ Posted September 9, 2012 Share Posted September 9, 2012 I use the following recipe for my green robes. It's simple, but very nice, IMO. You can use the old or new paints with the same effect, so I've listed both. Goblin Green/Warboss Green Base Coat Thraka Green/Biel-Tan Green wash (2-4 layers, depending, and I usually go on a little thicker than most) Goblin Green/Warboss Green highlight. You can do more to get more depth, but the washes really do most of the work. You are able to paint it really fast and do large groups at once. You are really just waiting on the washes to dry most of the time. Here are some pics of how this recipe comes out: Link to comment Share on other sites More sharing options...
Artemid Posted September 9, 2012 Share Posted September 9, 2012 Doctor Doom Marines! :) Those guys actually look very nice. I may try that recipie! Link to comment Share on other sites More sharing options...
Brother Nemiel Posted September 9, 2012 Share Posted September 9, 2012 Doctor Doom Marines! :) Those guys actually look very nice. I may try that recipie! I use it often but, Doc Doom is awesome! +1 for the color scheme! Link to comment Share on other sites More sharing options...
TMK0377 Posted September 10, 2012 Author Share Posted September 10, 2012 Those robes look awesome! I'm going to test that out! Link to comment Share on other sites More sharing options...
