Spaniard Posted September 12, 2012 Share Posted September 12, 2012 Hi all, This is probably the worst noob question but how do i go about makein the belial model since game workshop doesnt sell him as a seprate piece? Link to comment Share on other sites More sharing options...
Gillyfish Posted September 12, 2012 Share Posted September 12, 2012 Well, that rather depends on how you wish to approach the issue. The standard GW terminator captain mode makes a rather nice Belial with sword and storm bolter. Or you can use some of the parts on the veterans sprue to modify a plastic kit for the same load-out. Otherwise you can create your own, converting existing models or using other models as proxies, depending upon your skill as a modeller. Some people use Forge World models as a base. I used Lysander, used plastic arms and sculpted on some robes, but it very much depends on what you want to do. Hope that helps and welcome to the Rock! Link to comment Share on other sites More sharing options...
EPK Posted September 12, 2012 Share Posted September 12, 2012 ANd here is some inspiration - http://www.bolterandchainsword.com/index.p...howtopic=149901 Link to comment Share on other sites More sharing options...
Seahawk Posted September 12, 2012 Share Posted September 12, 2012 I simply use the DW sergeant from the Dark Vengeance box set as Belial. Link to comment Share on other sites More sharing options...
Azrael Turnbull Posted September 12, 2012 Share Posted September 12, 2012 My advice, wait until the end of the month before you begin anything. If a new codex hasn't been announced, then carry on. If it has, you can bet your Power Sword that he will finally have his own model. Link to comment Share on other sites More sharing options...
pueriexdeus Posted September 12, 2012 Share Posted September 12, 2012 Here is a good place to look at some of the others Belial conversions. Lots of options to explore. Link to comment Share on other sites More sharing options...
EPK Posted September 12, 2012 Share Posted September 12, 2012 Here is a good place to look at some of the others Belial conversions. Lots of options to explore. What, just because you incorporated it into a text link, it's better than mine above??? :( Link to comment Share on other sites More sharing options...
Cactus Posted September 12, 2012 Share Posted September 12, 2012 Here is a good place to look at some of the others Belial conversions. Lots of options to explore. What, just because you incorporated it into a text link, it's better than mine above??? ;) I find it impossible to spot text links using the Dark Angel theme - a slightly different shade of white just doesn't stand out. I assume others have the same problem, possibly with other themes as well, so I underline my text links now. That's such a good thread it's worth linking to twice anyway. Link to comment Share on other sites More sharing options...
EPK Posted September 12, 2012 Share Posted September 12, 2012 Here is a good place to look at some of the others Belial conversions. Lots of options to explore. What, just because you incorporated it into a text link, it's better than mine above??? ;) I find it impossible to spot text links using the Dark Angel theme - a slightly different shade of white just doesn't stand out. I assume others have the same problem, possibly with other themes as well, so I underline my text links now. That's such a good thread it's worth linking to twice anyway. I switched over to see - you're right. I'll stick to the B&C default. Link to comment Share on other sites More sharing options...
