"Fixing" Glossy Armour.
.Torch.
Like many of the members on the board I've been hard at work painting up the figures in the new 6th Edition starter box.
However, not being too familiar with the new washes I was a tad overzealous and now have a thin sheen that makes the armour a bit glossy for my liking. Is there an effective way to matt the armour again? Or will I have to strip the paint and start again?
Thanks,
Torch
https://bolterandchainsword.com/topic/260921-fixing-glossy-armour/
Some of the hardware store spray matt coatings will yellow with time so try to avoid those. Purity Seal from GW will not yellow but it is a bugger to work with and it will ruin a few models until you get the hang of using it. Brush on matt varnish can be found anywhere that sells artist paints; I like Windsor & Newton's Galeria Matt Varnish. 75mm cost about a dollar more GW's 12mm pot paint and will easily cover an entire army, vehicles and all.
[ETA]
And yes, the matt varnishes will dry clear. Nothing to add but a little water if it gets too thick.
I was just wondering whether or not the clarity was dependent on the quality. I'll mess around with a few, if I muck it up its just a good excuse to buy another DV box right? :D
I would suggest finishing all your models with a matte spray varnish to help protect them. It makes the paint jobs a lot tougher and will keep your hard work looking good. The best Matte spray out there is probably Testors Dull Coat: http://www.thewarstore.com/product33266.html
Another good one is Armory, it's cheaper for a large can so if you have a lot to spray (like vehicles and terrain) you may want to save the testors for your minis : http://www.thewarstore.com/product33266.html
Once you are done with the matte spray, go back and use a gloss varnish on things like weapon optics, jewels, or whatever else you want really shiny and not dulled down : http://www.thewarstore.com/product43297.html
