Priming errors
War Angel
I've been having trouble priming ever since my citadel primer ran out and I had to switch brands (my local store doesn't supply citadel primers).
For the past few years my priming has been flakey and absorbs the paint in weird ways making it difficult to actualy paint with any standard. I've been told this happens from priming in humid or moist weather, but I just tried today and I get the feeling I'm eater too close, too far, moving too fast or too slow.
Is there any advice that can help me?
https://bolterandchainsword.com/topic/261155-priming-errors/
I don't think you can really go too fast, and going to slow would just result in obscured detail. If that isn't happening, then it's probably something else.
The flakyness I've heard can be the result of spraying in direct sunlight, where the paint actually dries before it hits the model. You may also have an issue where you're not shaking the can well enough, or cleaning it properly after use (which can cause dried flakes of paint to be sprayed). These are just a few of the things I can think of, hopefully you can find out what is causing you these issues.
  Bymis said:
Get a big cardboard box and spray into that instead of going outside.
Well as far as spraying goes, spraying inside isn't such a good idea, because more than messing up the place the problem is the fumes. I found them to be a bit much even when I spray on my balcony. Basically I have to stop breathing entirely and/or use a mask, and even then the damn fume stench seems to follow me around for quite a while.
Direct sunlight eh? I actualy think I sprayed in direct sunlight as a mater of fact. I just so happen to have a can of krylon that I'll have to switch to. Im sick of the outcomes I've been getting, and I think my tactic of just going over it all in paint on primer isnt working well. I never had such problems when I was younger.
Thanks for the tips
I don't know if you can get it where you live but I think this stuff is pretty top shelf: http://www.thewarstore.com/armoryspraypaints.html
Even the matte spray is really good, only bested by Testors Dull coat.
As for spraying: Cool, low humidity, and not in direct sunlight. Spray from about a foot away and don't over do it. You can always practice on a piece of cardboard too.
Are your models clean? Some people have oily hands or maybe they just got a little residue picked up during assembly. Just give them a little scrub with a toothbrush with soap and water, Dawn soap IS the best. Let them dry thoroughly!
I've completely stopped using model company paints and instead buy stuff like:
http://shop.advanceautoparts.com/webapp/wc...plicolor+primer
Costs a fraction of the cost of primers from gaming companies, comes in multiple basic shades. I highly recommend it over Krylon as Krylon is both more expensive now that they have moved to the paint+primer line, plus Krylon seems to be heavier and will clog details. I've stopped priming outside since in Florida we have about 3 days out of the year when Humidity is not rampant, and instead prime in the garage. I think no matter what type of primer you use that will be an issue so it should be something you check before you prime. Weather.com is great for checking the general ambient humidity for your area. Let primer sit on the model for 1-2 days as well before painting for it to fully adhere.
I'll echo PipX in endorsing Duplicolor primers (black, white, gray and "hot rod gray," which is a dark charcoal gray prime). It's the best I've ever used, period.
