Thousand Sons dice
Well, you know, I guess it all depends on the changer of ways and his plans... :D
Even if your plans might not go as you'd wish, I'm sure that his plans are just going fine... :cuss
[Edit]: Awesome dice btw! Where were they from?
http://i112.photobucket.com/albums/n199/alexdarvell/DSCN5828.jpg
Just wanted to share with my fellow sorcerers! :blush:
You may want to read this before using those in a game:
http://www.dakkadakka.com/wiki/en/That'...nalysis_of_Dice
The rounded corners, the divots... good chance you will be rolling primarily ones with those things.
They are pretty tho.
is that an existing dice set, or did you design it yourself? if it is already an existing set, could you point us to which one exactly?
Just sent the guy at Chessex the image of the ouroboros and he did the rest. Custom dice can only be made using rounded edges and pips apparently because initially I had wanted numbers and square dice but that wasn't possible.
p.s. I've got plenty of round edged dice and the percentage of rolling more 1s is miniscule...plus you might want those 1s for toughness tests and/or psychic tests so I'm not so worried :P
