Gunslinger
Bearingtheword
With the FAQ concerning Wolf Scouts I beleive the list is Wolf Guard, Lone Wolves & up t o 2 Wolf Scouts in a Wolf Scout pack. Lone Wolves & Wolf Guard can have bolt pistol & plasma pistol or dual plasma pistols or Bolt pistols. The 2 Wolf Scouts in a pack may have a bolt pistol & a plasma pistol. Double check that 'cause I could be wrong.
https://bolterandchainsword.com/topic/261701-gunslinger/#findComment-3185730
Sounds right. Which reminds me ....I've been meaning to open up a "Show me your Gun Slinger!" Thread. :woot:
https://bolterandchainsword.com/topic/261701-gunslinger/#findComment-3185733
Sounds right. Which reminds me ....I've been meaning to open up a "Show me your Gun Slinger!" Thread. :D
Go for it Rags, mine is almost ready:
Painter didn't paint the black background on the shoulder pad behind the skull, so I've got to take care of that myself.
Valerian
https://bolterandchainsword.com/topic/261701-gunslinger/#findComment-3185747
What about Grey hunters? Not an option?
Sadly no. The closest Grey Hunters can get is a Bolter in one hand and a Bolt Pistol in the other, which looks cool but doesn't qualify for the "gunslinger" rule. I had modeled two of mine that way in the excitement over the new rule and now am going to have to go back and change them ;(
~BtW
https://bolterandchainsword.com/topic/261701-gunslinger/#findComment-3186725
~BtW
Not really since they have those as base wargear,now if you had modeled him with 2 pistols then you would either have to switch arms or promote him to WG
For pistols why not use 2 plasma?nothing could stand in your way
https://bolterandchainsword.com/topic/261701-gunslinger/#findComment-3186750
~BtW
Yup, not bad for 48pts
I'll be doing at least one that way...
~BtW
https://bolterandchainsword.com/topic/261701-gunslinger/#findComment-3186874
  • 7 months later...
Gotta wonder though, whether 1 bolt pistol and 1 plasma pistol might be in some ways better. More wounds and melee attacks per point spent, and the bolt pistol still does something, even if it's not nearly as good as a plasma pistol.
It lacks the awesome factor. There are a lot more models that can do BP/PP than can do 2X PP.
https://bolterandchainsword.com/topic/261701-gunslinger/#findComment-3377469
ive run this unit the last 2 games -
wolf priest - P.Pistol, Saga of the hunter, M.Bombs
WGPL - P.Pistolx2, MotW
Grey Hunters x10 - 2xPlasma, Wulfen, Banner, P.Fist
I usually dont bother with the powerfist in my grey hunter units, but take one in this as its my 'HQ' unit and lacks some high strength AP2.
Great fun to use, hilarious number of plasma shots upon outflanking (usually where you want cos of acute senses), and a high number of close combat attacks cos of the two wulfen.
https://bolterandchainsword.com/topic/261701-gunslinger/#findComment-3377474
Wouldn't it be better off having Melta rather than Plasma so you can fire special weapon and assault?  I know you can't assault on the turn you come on but spending points on 2x wulfen basically says you want to be in combat with the unit.  If you are firing plasma you're not assaulting.
https://bolterandchainsword.com/topic/261701-gunslinger/#findComment-3377508
10X S7 shots before the second turn charge vs 6X S7 + 4X S8 isn't really a significant difference against Infantry, until you factor in the possibility of getting charged.  The extra Overwatch shots from the Plasmaguns would be better than from the Meltaguns.
https://bolterandchainsword.com/topic/261701-gunslinger/#findComment-3377522
Good point.  :D
I was thinking of rear ending tanks but the MotW makes the unit geared up to take on troops rather than tanks.  If the unit didn't have MotW in it I'd go for the melta, targeting tanks especially with the melta bomb and power fist in the unit.
If the unit is only really going after troops then maybe it's worth saving points and having a power axe?
Still working out what's worth taking myself.
https://bolterandchainsword.com/topic/261701-gunslinger/#findComment-3377549
