Bartali Posted September 25, 2012 Share Posted September 25, 2012 Any ideas for a modeling a Force Axe/Storm Shield TDA Librarian ? There's a few options as far as I can see :- - The old metal TDA Librarian with force axe. I do quite like this figure, but unfortunately the axe is in his left hand - the same hand that Storm Shields use. I don't fancy doing metal conversion work (shifting the axe to his right hand), so are there any right handed storm shields out there ? - Plastic TDA kit, using a frost axe from the Wolf Guard box. Any idea which hand the axe sits in ? Any other options (trying to stay away from using a GK Halberd) ? Link to comment https://bolterandchainsword.com/topic/261767-force-axestorm-shield-tda-librarian/ Share on other sites More sharing options...
Leonaides Posted September 25, 2012 Share Posted September 25, 2012 get the new termie lib and an older PA librarian with an axe, cut off the axe, add to terminator. If you're careful with the cut you could pu tthe force staff onto the PA guy as well (and still have 2 complete librarians). Storm shield can be from the assault termie box or Space Hulk, or a certain IF First Captain...... Link to comment https://bolterandchainsword.com/topic/261767-force-axestorm-shield-tda-librarian/#findComment-3186059 Share on other sites More sharing options...
Zedrenael Posted September 25, 2012 Share Posted September 25, 2012 If you can get your hands on the older librarian models with force axes. They both have the force axe in their right hand. Link to comment https://bolterandchainsword.com/topic/261767-force-axestorm-shield-tda-librarian/#findComment-3186065 Share on other sites More sharing options...
pueriexdeus Posted September 25, 2012 Share Posted September 25, 2012 Another option would be to cut off the Hammer head and the Axe head, then pin the Axe head to the shaft of the TH. Link to comment https://bolterandchainsword.com/topic/261767-force-axestorm-shield-tda-librarian/#findComment-3186277 Share on other sites More sharing options...
The_Chaplain Posted September 25, 2012 Share Posted September 25, 2012 One not mentioned so far: get a spacehulk librarian which comes with a force axe, and then purchase a storm shield and arm for it. File off the blood angel icons, add bits to your personal taste and voila! Link to comment https://bolterandchainsword.com/topic/261767-force-axestorm-shield-tda-librarian/#findComment-3186595 Share on other sites More sharing options...
fivepointedstar Posted September 25, 2012 Share Posted September 25, 2012 you could also take the Librarian TDA model and arm him with a right handed shield from this guy. and model him with one of the chaos axe arms for a right handed axe. ( you may need to bless, and re-bless the right arm thou) And the old school librarian TDA model/ Rune Priest also have a right handed axes. Link to comment https://bolterandchainsword.com/topic/261767-force-axestorm-shield-tda-librarian/#findComment-3186629 Share on other sites More sharing options...
Bartali Posted September 26, 2012 Author Share Posted September 26, 2012 Another option would be to cut off the Hammer head and the Axe head, then pin the Axe head to the shaft of the TH. Why didn't I think of that ? Probably the easiest option, and I have a fair few Power Axes lying around from Assault Marine boxes Link to comment https://bolterandchainsword.com/topic/261767-force-axestorm-shield-tda-librarian/#findComment-3187234 Share on other sites More sharing options...
Zhodair Posted September 29, 2012 Share Posted September 29, 2012 I used the TDA forcestaff Libby, cut off the staff tip and replaced it with the sanguinary guard axe head.. Then assault termie shield with alittle gs work to make it Libby like.. Link to comment https://bolterandchainsword.com/topic/261767-force-axestorm-shield-tda-librarian/#findComment-3190931 Share on other sites More sharing options...
