Brother Captain Andrew Posted September 26, 2012 Share Posted September 26, 2012 Before the avalanche of "USE SEARCH" I've been doing the layering method over black primer and getting ok results, however I'm out and am going to buy the new paints. Has the new paint range changed how white is painted with the new white ceramite base coat, or is it still best to use a base of something like Administratum grey and then layer up to white? Any extra help and or tips to painting white would also be greatly appreciated. Thanks in advance. Link to comment https://bolterandchainsword.com/topic/261864-painting-white-with-the-new-citadel-paint-range/ Share on other sites More sharing options...
henrywalker Posted September 26, 2012 Share Posted September 26, 2012 i've just started using a great way for my white chaos marines. i prime them with white using krylon fusion matt white (it has a very fine spray. then i make up a wash using lahmian medium, dawnstone grey and a little bit of the old necron abyss (tiny bit) its a very thin wash. i do a medium layer all over the model and a heavy layer on particularly contrasting bits. i also pick of ht really recessed areas with nuln oil. once thats dry i do a zenithal spray. this is where you take the model and spray from the intended light source (ie above) in a spray thats gentle enough to just cover the top read, ie where the light would hit, i've got very pleasing results and all with very low effort. to get an idea of how the zenithl spray works take a black model and try to spray white from the top, look at the effect you get. Link to comment https://bolterandchainsword.com/topic/261864-painting-white-with-the-new-citadel-paint-range/#findComment-3187790 Share on other sites More sharing options...
henrywalker Posted September 26, 2012 Share Posted September 26, 2012 ah, i may not have been to clear on this, the wash stains the white slightly darker so when you do the top spray you get a shaded effect Link to comment https://bolterandchainsword.com/topic/261864-painting-white-with-the-new-citadel-paint-range/#findComment-3187801 Share on other sites More sharing options...
Razblood Posted September 28, 2012 Share Posted September 28, 2012 Ceramite White will usually go over Black in 2-3 coats in a 50/50 ratio with water (I assume it would be the same with Lahmian Medium) but beware of the paint splitting if you thin it with water, had this happen to me a couple of times ;) But it is simple fact that the best way to get a clean, smooth White is to base White :) Best of luck ;) Link to comment https://bolterandchainsword.com/topic/261864-painting-white-with-the-new-citadel-paint-range/#findComment-3190083 Share on other sites More sharing options...
Warbringer Posted October 2, 2012 Share Posted October 2, 2012 Use the grey and white from White Dwarf using the GW colours it works really well. Link to comment https://bolterandchainsword.com/topic/261864-painting-white-with-the-new-citadel-paint-range/#findComment-3193526 Share on other sites More sharing options...
