mk iii arms
skeletoro
I am thinking of getting a few mk iii models for wolf guard. Though I haven't 100% settled on a loadout, I'm tossing up between:
power sword + axe
bolt pistol + sword or axe
combi-weapon + sword or axe
However, the forge world ones have arms set up for holding a bolter (in two hands).
I know that I could just use different arms, but the mk iii arms have their own aesthetic that I'd like to conserve. How might I go about "opening up" the arms so that they can hold two weapons? Has anybody tried this, and had good-looking and durable results?
https://bolterandchainsword.com/topic/261901-mk-iii-arms/
I've done it, I'll edit in a pic.
You will need to pin every cut/adjustment you make. Time consuming? Yep. Worth it? Totally.
Also, the hands were quite tedious, as you cant just cut them off if you wish to preserve the mkIII athestic. You'll need to very carefully carve the hands out of the armour, then shave the back of the ccw hands your putting in.
Cheers,
Jono
https://bolterandchainsword.com/topic/261901-mk-iii-arms/#findComment-3188468
