Contemptor Dreadnought Magnetising Help
As in, have it posable or removable? Either way, the answer is smaller magnets. As far as saving detail goes, you could sink the magnets on the torso a little deeper (0.5 to 1mm) than normal and smooth over the gap with green stuff.
Cheers,
Jono
try drilling a hole and setting the magnets in, then put a very thin layer of contour putty (green stuff and or miliput would work as well) over the magnets and sand /file it flush, and do the same with the launcher. Unless you sink the magnets REALLY deep it should hold just fine.
