Dark Heart of Cthonia
esinhorn
So today I want to paint another tank but I am feeling on the lazy side and do not want to build.
That means it is the perfect opportunity to give one of my old tanks a repaint.
This is a Vinidcator in the old shade I used when it was not canonized a very pale
scheme.
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/bd5739113d229b2338fba8f22f83700f.jpg
Not bad but it will not fit in with the existing tanks.
The first stage was to use a large oxhair brush and wash it with soap and water.
This is to remove any loose wreathing powder and real dust that built up of time,parked on the shelf.
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/0cc5bc427a1b0a7fb678ee800cd78837.jpg
Then I prepped my brass in AK Photo-Etch Burnishing Liquid.
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/f3a882d7a4daf64bd878c867ff033438.jpg
This is a optional step that I like to do,it helps grip paint better and if it gets scratched you will not see a blaring line of brass shine.
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/3f9fa4dc9cfd93c23b1cdace99c1b3e2.jpg
I attached the etch and masked the barrel,I liked how it came out so I am keeping it.
I then sprayed a couple of coats of Tamiya Hull Red.
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/cb89b697d85a16e9561aecfb1a44ced2.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/b9a0a776652f7a54c1feadf19f509c2d.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/874e1e6e5ecb5d0ea3911274aa3dcca3.jpg
Tamiya is ideal for the base layer for the thinners and stuff I use,it is super durable.
Now I am letting dry while I go to work,
The next step is to spray the Hull Red with 2-3 thin coats of AK Worn Effects or Hairspray letting each layer dry before adding the next
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/e6363fb1c3f84089609fef1d054d4ae1.jpg
Once Dry I basecoat the tank with Tamiya Black-Green
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/231f89f31a7fd2ff9e2516da795dac86.jpg
Then I spray another layer of Worn Effects
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/7d66e0dcb2dc7f45b76f03f77976af2c.jpg
Once that dries I then lay down the main color which is a lightened Field Grey
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/bfbfed0bece22eea7b2add41df785d0a.jpg
And I spray the highlight with Sky
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/64403a01af31526f154e57b37ce246e2.jpg
The tank looks pale again at this stage but weathering darkens the paintjob quite a bit.
So you want to start out a few shades lighter than you want.
Using a cocktail stick I make random sratches,not too many
I try to place them where the tank would rub off paint clipping the side of a wall,or powering through low rubble.
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/4ce6f8593c4132ae9a1b86c2f03ea6c2.jpg
I then use a flat brush and water and proceed to rub off the paint where it would see wear and tear,the hatches,along the top where a guy would enter/exit the top hatch.
I concentrate on the hard edges and lower hull.
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/f0d426a0ed754d5c8ce8d9b5e94ed978.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/8ba52971039a759fbc53103910e70275.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/8883e927ab0b5f77ae83a9f2681b6408.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/0f9b094d6a7c45b37c2afe484d2d2c86.jpg
Once you are happy with the amount of chipping seal it in with 2-3 light coats of Semi-Gloss varnish.This will prep it for the further weathering steps
Now I give the entire tank a filter.
I used Blue for Grey vehicles to add a blue tint bringing it a bit closer to the Power Armor.
But it unifies the tone tieing everything together.
You want a Filter 10% paint 90% thinner,you wet the whole tank with it but do not let it pool.
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/96d3647286c6f01f55c7a8741a44b2d3.jpg
I sealed this again with a layer of semi gloss and painted all the details,also painting all the rivets a lighter green to make them pop when they get the pinwash.
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/51c0f0095eeae229f1dfd96fdcc2161c.jpg
To give the impression of being sun-bleached I added a few small dots of white flat enamel then worked them in with thinner.
It is a subtle effect and it is easy to overdo
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/647637a002fe0d3ac3d855376648d0d5.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/3ab6ccac02c2d04d3e66f0698a4aa7ce.jpg
Next step I add the Streaking grime.This represents run-off from things such as nuts,bolts,and brackets.
I paint the streaks directly from the bottle,placeing them where I deem fit
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/13a4abe37295a22f9c777184ab8139c5.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/7dcb1ee0060b0a9797d1e83db1de37b9.jpg
I then use a flat brush dampened with thinner and diffuse them in a downward motion,blending them in,what is left is a subtle run-off look.
If you want it stronger just do it a few times.
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/b965bf19941c82e03f7249078f09c312.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/4febf7a5d90ab2b2bf0e7ae9e2f7d0ff.jpg
Once finished the work gets sealed with a layer of semi-gloss
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/51c1b2fc2349706e3ea5b4a80f80dad6.jpgAt this point I basecoat the tracks a flat brown in this case Khermi Brown,I then applied AK Track wash direct from the bottle.
I wanted a couple of decals.
I prep where the decal is going to go with Ardcoat
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/7fd15786cd5e02eac5f36c472e729dd8.jpg
When Dry I use Micro-Set instead of water,I soak the decal in a capful of Micro-Set and then apply as normal.
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/582d559395ddcb492e2d99b0f86d1813.jpg
Once that is down I brush on some Micro-Sol to help snug it down.Not really needed in this case but when you have to do a shoulder pad this stuff is gold.
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/e6d341f98300e6398e10aa99840a43cd.jpg
When dry I go over the decal area again with ardcoat to seal the edges and make it look painted on.
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/403a2049e63e1b8e6658d1c0f7904258.jpg
When that is dry I give the model a couple of coats of Semi-Gloss to make everything the same sheen again
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/ce26c7c0fea91af0b438c86907887992.jpg
The next step is the fun part,the Rust Streaks.
I paint Rust Streaking grime down the side originating from the red chips.
Then blend them in a downward motion with thinner to diffuse them
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/bd2c86553e708dc37a95e5daba1d1317.jpg
Once you complete this I give one last coat of semi-gloss and when that dries 2-3 coats of Flat.
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/1aefa532de5b41d172d4fa5caefe8976.jpg
Hey Don I forgot to mention to you.
The
Phobos pistols are a perfect match both in holster and also the empty assault holder same size and scaled for the pistol.
Now if they would also come out with left side holster I would be a very happy man.
But I happen to love the round eye with the ends that curly cue up.But the brass is only slit style,so....
But I like the slit too it does look more menacing
Now I add rainmarks,using the same method as the Streaking Grime and Rust
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/594a87d996328fc39301c3c8612c1132.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/e451d53e701d5429bfe257accad1da3c.jpg
And use Light Rust wash to reinforce the rust streaks
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/3580545fe904f84337ce130f6df05529.jpg
Now time for road dust
I attach the dozer blade and make a super thin mix of Tamiya Buff 9 parts thinner to 1 part paint and spray the lower third of the tank making sure the rear gets a bit more
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/b97037e9c96a026bbd4435373ca80604.jpg
I then work in European Earth powder into the tracks sealing it with thinner
when it gets damp and not wet I dust a little more on.
The damp thinner seals this and it stays nice and dusty
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/ef74f31879fe492c64e5161d5d938731.jpg
I then put some AK Dark steel on my finger and rub it on the highpoints and edges of the tracks where it would meet the road.
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/328774f5cbfe2c2b603629e934da4a77.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/b0897fee9ab1977a675dac15dda93f18.jpg
I then add water to Track Rust powder and paint this patse on the exhausts,when they dry I rub on sone steel to the edges of this too.
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/e904662057a0e44f5a84ec9d87da1796.jpg
I then use Black Smoke and dust the area of the exhaust fans and the tops of the exhaust pipes.
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/cd9cdd0c5dd793728c8b55295e13b1d2.jpg
I also sooted the blade where the cannon is
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/f117b51026710b7f2a85b6af4379f7e1.jpg
I finished him up a little while ago
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/cc941e0d779b446aa616465cec6ea4e3.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/f2dbd73dc615b441b9f268ed30b02f97.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/0c888568eb1124e5d73a6764214b6b4d.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/b9955939811ef4e936f53054d3e8662c.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/1fffda3c09f82a26a197bd65d24c2ad6.jpg
I was going to do this one tomorrow but I just couldn't wait
The Missile Launching Jumpack Destroyer with Rad Missiles
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/ec21ffca2d77a84f1bbb57b7f9c7bb2d.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/bd80fc8ead19418fb573196b3ca2a707.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/68cebc2e7e28cab0a68e9b38750167ec.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/d17a55576531392bc9e5a091d6ef3407.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/44116640d2772d817d4a62a414f41701.jpg
Thanks to a bit of shoehorning to make work,then a Friend says why not just use the Mk4/BA jumpack
Doh.
But this way he'll match the squad.
I finished a Nuncio-Voxman
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/e18691bd758170b48ac9a5adca9c2ca6.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/e972beba6957a9fd458d0c5560e45c29.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/de0e32b11b403b99bf9d1a570198eb02.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/de8d90d9e87a06d10800526e24470ebf.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/2091472151b6fe42baf6db3abe7661c9.jpg
Doh.
Finished off another Bolter Brother
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/3364952dca92e9488d138f43faa450bb.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/42a62a59e60f2715efad7f6ffd9405c2.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/7e15cdb90508e68fc6db7e7d6d6c4f5e.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/b4caa9336b4529efd8f0accf07f23572.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/5a70a83570e6ff055263f83c3a1f5241.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/9f8561dd7729e558d932fd02b6739202.jpg
I am prepping the rest of the autocannon support squad right now,but I worked on the Dred Drop Pod earlier today
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/db6de0a1908ba4ec5f72cf47931714b0.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/803b07eb812a0cfb3fe3e43158efaa04.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/bdd0a629bfbafa384ba7d597017fb7ed.jpg
Finished off my Autocannon squad today.
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/2bb274fe1d7fa0a8a4c761ff9b22f217.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/749222f0905ef9e68c2b834eb5ccca46.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/482c66f80d2997e674f475b9d7d144fa.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/b3797753b01e84de39ec70bf6f2ebce2.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/6b59e86d699a8776166eee12a6285ea9.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/91c9a0f438a056b9d3dcebcb616d1e8a.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/9ec0402ee58b524a6d479f5dbddf2cb2.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/7ae43db4e9f2b171d74572fff1f0f3b2.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/2e7f7bb4496a49e761175b858da247fe.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/991bb0ccf2e7e8aae03a6674297c6b12.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/890f8bfec2a9c2d2aa90a51a91fee986.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/910f2a856818158e6f33a42a88cea2ac.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/58d1b27d46b7cda24af708f1b40f4e67.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/42e7de4a4b7fdafbd37a50eafefe850a.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/93e64b27b7e4322bdff30033d8a59077.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/9dd0e2990058fe4f647654d7e4836cd5.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/2ff6c983a84e4de9904c7ed1c6f3b8c8.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/442b09e36e810e27a06731e90c336aa8.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/6891bd7359d81815947502939290d11d.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/2727a197a21c4fd9237a2dedf339039f.jpg
I built this one as a nod to old school termie style back banner for the command banner bearer
Not sure what 1st companies standard would look like.
But as his place in the command squad I swapped his combi-bolter out for a plasma blaster and Thunderhammer
This Bearer has a bite
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/fbe996fb8e24b136bdecdab9f3f465fc.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/858a2890147b22891d9b1339eb3dd46b.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/fc54c2e5a64af65ae805359cc3c6ddc8.jpg
Figured out the banner design using decals
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/1a147924a108a47b315b34ef9456cf90.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/8f03224e56fde22806d447cf366ebd02.jpg
I have the banner bearer finished up.
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/e14fdb443015d1e3dfe058f3b6e64d9b.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/27085a3543719dc7dee15bb33549fd4f.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/938c3a2534f1d79ec7b2a7f800555dec.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/b9769a078296eb8665be88456f1fd9ef.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/dce246510b2d3c0bc68bccd82d63a45d.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/bbb3c8fd5c46b3085bdb08c9f345392b.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/67752bdce26106ab61111c24cb748fd4.jpg
I have starting fleshing out the Missile support squad.
This one is my favorite of the bunch
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/eb7bf94761a89da01c66174c232305a2.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/c586aeed0426bbc0008d8da4fe31661f.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/9a329f800153db001be647bb407d24c5.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/c56ed43c7fd0a8598227fe848d6ae626.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/4c8d7e91556d42f29486076fcb3b0227.jpg
http://i216.photobucket.com/albums/cc52/Esinhorn/Will%20Wright%2040k/4bea615880732dc255613b70d496f975.jpg
