Twin Lightning Claws?
I was looking over the Codex and I noticed something odd. There are no Twin Lightning Claws. And everything I am seeing says "May take one item." So does that mean twin lightning claws no longer exist?
It exists - units that can use them have another bullet says that you can instead replace both weapons for a pair of LCs for a X cost.
They are there.....
Pg 91 Terminator weps.... you can replace the ranged wep and then the power wep with 1 each
Pg 96 Chosen under "Replace Bolt Pistol, close combat weapon and bolter with a pair of lightning claws...."
Pg 97 Chaos Terminators "May replace his combi bolter and power weapon with a pair of lightning claws..."
pg 94 Melee Weapons .... "a model can replace his bolt pistol and/or Close combat weapon with one of the following...." So Champs with access to the armoury can have them....
~BtW
