Plague Champion
There is a strong argument to leaving the champion nakked. With t5 and fnp though it may be worth it to consider tossing him a power axe. Most unit leaders aren't really that killy and even those that are probably will still wiff often enough to let a small cost upgrade be worth it.
What do you guys think?
https://bolterandchainsword.com/topic/262668-plague-champion/
I think I'm going to try Power Mauls on my champs in my melta squads. I feel they need something with a little oomf, but fists just don't seem worth it if they have to challenge someone. On my objective camping plasma squad, though ... naked champ for sure. Can't hurt to just leave them with Poisoned attacks, since they shouldn't be in melee as much.
I think the majority of my Champions over the years have either had a Power Fist or Plague Sword... and I can't see that changing. I always like having a tough as nails character to pack that extra bit of a punch, that will also enable me to deal with whatever is coming at me.
Also our lower Initiative means that going last with the fists is not a big deal. We are already going last against MEQ, might as well get smashy!
That's a good point. Not sure why I wasn't thinking that ... looking at cultist stats too much or something. Fists forever.
Im thinking Axe since its cheaper
It's all in the hits, really.
1 Meltabomb attack = .66 average hits when vehicle moves
3 Powerfist hits = 2 average hits when vehicle moves
vs AV10
MB = 3% glance, 97% penetrate
PF = 17% glance, 67% penetrate, 17% fail
vs AV11
MB = 6% glance, 92% penetrate, 3% fail
PF = 17% glance, 50% pentetrate, 33% fail
vs AV12
MB = 8% glance, 83% penetrate, 8% fail
PF = 17% glance, 33% penetrate, 50% fail
vs AV13
MB = 11% glance, 72% penetrate, 17% fail
PF = 17% glance, 17% penetrate, 66% fail
vs AV14
MB = 14% glance, 58% penetrate, 28% fail
PF = 17% glance, 83% fail
The MB then has a 50% chance of vehicle kill, while the PF has a 33% kill chance (67 and 50%, when open-topped).
So, if I can haz right maths, it'd be:
32% chance for a charging MB to kill moving AV10, and 44% for a charging PF to kill moving AV10.
30% " " " " " ", and 30% " " " " " ".
27% " " " " " ", and 22% " " " " " ".
24% " " " " " ", and 11% " " " " " ".
13% " " " " " ", and 0%.
If you want in think in terms of HP reduction (and kill), the PF generally wins out for bringing more attacks.
I'd still rather wound T6 on a 2+ ;).
In my plague marine squad with 2 plasma guns I was thinking of simply giving the unit champion a combi bolter and leaving his plague knife alone.
It's worth bearing in mind he has three weapons... bolter, bolt pistol and plague knife. You're allowed to swap any or all of them so you could take a power axe for the bolt pistol and keep your plague knife and swap out your bolter for a combi flamer for instance...
I've been bringing a combo of Power Fists and Power Axes. Our Initiative is the pits anyhow, so does it really make a difference? I also have been taking Mutation on them, mainly to try it out but I've had some nasty results. Last game I played was +1 STR on a Power Fist, FNP on two of them (4+), and Shrouded.
Where does it say that the boons stack? This happened to me, rolled FnP on the boon, but I just considered it a fail because I couldn't find anything that says it's a +1 if you already have the trait.
A long time ago when there was grand tournaments and I played in them with my all-Nurgle army and you got the free champ with 7 man squads. I would try to find the 5 points for melta bombs for some of my sit still and shoot plaguemarine squads. Obviously no upgrade but the extra attack is an option. But a number of games even at big tournaments, people have ignored the lone champ or the remnants of the squad and driven too close, only to have my Plaguemarines run out from behind a wall, charge up to the side of a tank and clamp a melta bomb on the side.
All you need to do is destroy one tank in a tournament for a 5 point melta bomb to pay for itself.
Plaguemarines had krak grenades in the last book, I built a champ model with four different grenades on his belt. Melta bomb + power weapon is cheaper than a power fist and is an expensive but valid option. Generally when you have 6 or 7 plaguemarine squads it is good idea to give each champ a lowly melta bomb with one or two being armed for assault, then spend all your points on power fists and then run a bunch of a naked champs.
Visually I like all my models to look different, my first army list will have six differently armed Plaguemarine squads in it, so I can test, but I'm thinking Plasma will become a lot more popular again.
I also am a fan of the combi-flamer on my champ. I have two champion models with powerfist and combi-flamer. This is very expensive so I usually run one champ like that and the rest considerably cheaper. I send the souped up champ where the fighting should be in a rhino generally or even a Landraider and the rest of the squads hold ground or provide cover support. I also use Elites and HQ to support my assault Plaguemarines.
