ianj253 Posted October 9, 2012 Share Posted October 9, 2012 Hey all, I had the rhino from the BA battle force and was wondering what bits I would need to buy in order to make it into a baal? Of course the turret and side sponsors, but is there anything else? Link to comment https://bolterandchainsword.com/topic/262804-making-a-rhino-into-a-baal-pred/ Share on other sites More sharing options...
Kem Posted October 9, 2012 Share Posted October 9, 2012 also you will need a model knife, glue, brush, primer and paints ;) Link to comment https://bolterandchainsword.com/topic/262804-making-a-rhino-into-a-baal-pred/#findComment-3201564 Share on other sites More sharing options...
Zedrenael Posted October 9, 2012 Share Posted October 9, 2012 Well the front is slightly different but I do not think it really matters. It is a single window instead of the double window. Link to comment https://bolterandchainsword.com/topic/262804-making-a-rhino-into-a-baal-pred/#findComment-3201680 Share on other sites More sharing options...
Morticon Posted October 9, 2012 Share Posted October 9, 2012 Well the front is slightly different but I do not think it really matters. It is a single window instead of the double window. Very important if you want to claim the AV13 :) that one window!! :P That's really all you need though dude, the turret and sponsons. Link to comment https://bolterandchainsword.com/topic/262804-making-a-rhino-into-a-baal-pred/#findComment-3201850 Share on other sites More sharing options...
Ushtarador Posted October 9, 2012 Share Posted October 9, 2012 Turret and sponsons are enough. Gogo magnetz all the way :) edit:/ Stop spamming mort! : O Link to comment https://bolterandchainsword.com/topic/262804-making-a-rhino-into-a-baal-pred/#findComment-3201852 Share on other sites More sharing options...
Demoulius Posted October 9, 2012 Share Posted October 9, 2012 WELL!!!! You also need the shiney Blood angel Icongraphy that comes with the Baal :huh: Link to comment https://bolterandchainsword.com/topic/262804-making-a-rhino-into-a-baal-pred/#findComment-3201919 Share on other sites More sharing options...
Xenith Posted October 9, 2012 Share Posted October 9, 2012 You need to buy the Lucifer pattern engines. Link to comment https://bolterandchainsword.com/topic/262804-making-a-rhino-into-a-baal-pred/#findComment-3202023 Share on other sites More sharing options...
SnorriSnorrison Posted October 9, 2012 Share Posted October 9, 2012 You need to buy the Lucifer pattern engines. This! The only possibility to get one is the Baal kit, and without, your Rhino-based Baal won't be fast! It's very important for your gameplay as this makes your tank a normal tank and it won't be able to keep up with the rest of your force. :P Snorri PS: Oh, and it needs to be red as well....you know, the red ones are faster! :) Link to comment https://bolterandchainsword.com/topic/262804-making-a-rhino-into-a-baal-pred/#findComment-3202087 Share on other sites More sharing options...
