Verythrax Draconis Posted October 9, 2012 Share Posted October 9, 2012 Hi, just a quick and simple question on modelling nurgle marines. Are you guys ok playing against someone using normal CSM models, painted in a nurglish color scheme, as plague marines? Or do you guys consider imperative for them to be modelled using the Finecast/FW models? I ask because I have tons of marines and access to a lot of chaos bits, so I don't really feel like buying more marines. I'm planning to drill the 3 holes symbol on them, paint them as using rusty/rotten PA, and purplish flesh. Would that be fine? Link to comment Share on other sites More sharing options...
John_f Posted October 9, 2012 Share Posted October 9, 2012 I can't answer for all your opponents but I can't imagine anyone having an issue with this. This is truly an non issue because if they are so spitefull as to not accept your converted regular CSM as PM, you do not want to play with them anyhow. Link to comment Share on other sites More sharing options...
Verythrax Draconis Posted October 9, 2012 Author Share Posted October 9, 2012 Thanks, I just want to feel what the general consensus is. Please people, share your opinion as well :P Link to comment Share on other sites More sharing options...
breng77 Posted October 9, 2012 Share Posted October 9, 2012 For me as long as the models are equipped properly (Bolters, Special weapons etc.) and you either a.) Use only plauge marines. b.) Can differentiate between squads of plauge marines and other marines. I really don't even care if they are painted to look nurgle. Link to comment Share on other sites More sharing options...
Ammonius Posted October 9, 2012 Share Posted October 9, 2012 As long as I know who is who and what is that, I'm good to go. It sounds like you would be converting your models, so that's even better. Link to comment Share on other sites More sharing options...
Azekai Posted October 9, 2012 Share Posted October 9, 2012 I would encourage you to get some greenstuff and make them bloated, or, if like me your greenstuffing skills are lacking, get zombie gut bits and stick them on there. Heck, don't even use bits, just glue coiled electrical wire into hollowed-out torsos. Link to comment Share on other sites More sharing options...
Serricus Posted October 9, 2012 Share Posted October 9, 2012 I wouldn't worry too much in non tournamant setting. Most people won't care as long as equiped properly. Just explain before game so it's not a sudden shock. i'm working on a fallen dark angels chapter (rescent fall) that turned to nurgle. The DV marines form the base of my plague marines. just drilled some holes and painting leaking ooze as cleaved to differenciate.. Link to comment Share on other sites More sharing options...
Circus Nurgling Posted October 9, 2012 Share Posted October 9, 2012 As long as I don't or wouldn't be confused by them on the table, I'm happy. Link to comment Share on other sites More sharing options...
cypher 89 Posted October 15, 2012 Share Posted October 15, 2012 hey ya , i run normal marines as my plague marines have a look at them http://www.bolterandchainsword.com/index.p...howtopic=263049 i bloodyed them up and made them look a bit gruesome , i am adding some FW models but these will peob be my champions in the squads. Link to comment Share on other sites More sharing options...
emrys Posted October 15, 2012 Share Posted October 15, 2012 as everyone has said already - as long as the weapon load out is correct it would be perefectly fine with me (and most normal rational players) Link to comment Share on other sites More sharing options...
Kelanen Posted November 3, 2012 Share Posted November 3, 2012 It's absolutely fine for friendly play. It's pretty much a no-no for competitive play. You can't use any model that could be interpreted to be another model from the same codex, Even moreso, now CSM can have mark of Nurgle. Outside of a tournament you should be golden, but I'd check with a TO for a small shop tournament, and assume not for any big tournament. Link to comment Share on other sites More sharing options...
Azekai Posted November 3, 2012 Share Posted November 3, 2012 The line is really blurry considering that many players convert their Nurgly troops. I have several 'mere' CSMs that serve as plague marines, but they have Death Guard shoulder pads and/or possessed bits. I have taken them to tourneys mixed in with my metal plague marines, a few forgeworld guys, and even some of the adorable vintage plague marine plastics. No one has complained or even noticed. Where do you draw the line? I am not sure what makes a plague marine, but I know it when I see it. Link to comment Share on other sites More sharing options...
