minigun762 Posted October 10, 2012 Share Posted October 10, 2012 I know that big box kits tend to be more simply made, so I wanted to check on how much play you have with the hellbrute. I'm hoping for the ability to just swap basic dread arms with it but I'm guessing not. Is the fist arm limited to the single high position? Link to comment https://bolterandchainsword.com/topic/263014-how-customizable-is-the-hellbrute/ Share on other sites More sharing options...
Grotsmasha Posted October 10, 2012 Share Posted October 10, 2012 It's not easily convertable, besides the gunarm, any other converting will require greenstuff work. Cheers, Jono Link to comment https://bolterandchainsword.com/topic/263014-how-customizable-is-the-hellbrute/#findComment-3204084 Share on other sites More sharing options...
Urauloth Posted October 11, 2012 Share Posted October 11, 2012 Not convertable at all unless you want to lay into it with a razor saw and a pack of greenstuff. It's prettymuch just a two piece model with bits for exterior detail. Here: http://i.imgur.com/qqTAh.jpg (image courtesy of the bitz store) Link to comment https://bolterandchainsword.com/topic/263014-how-customizable-is-the-hellbrute/#findComment-3204265 Share on other sites More sharing options...
minigun762 Posted October 11, 2012 Author Share Posted October 11, 2012 Thanks guys! Good to know. Sounds like I might try my hand at the loyalist Ven Dreadnought instead. Link to comment https://bolterandchainsword.com/topic/263014-how-customizable-is-the-hellbrute/#findComment-3204274 Share on other sites More sharing options...
Lord of Blades Posted October 11, 2012 Share Posted October 11, 2012 Actually... It is pretty easy to convert if you want it to keep that power fist... I for example have turned my Helbrute into a Reaper autocannon wielder and kept the Pow fist. IT was an easy convertion that apparently no one had thought of... USe two Imperial Autocannon barrels. Cut them a tiny bit and then attach them into the Helbrute melta gun. They look fine if a bit weird, but when painted look great. For a Plasma cannon, I would probably cut the Lower melta cylinder, add in a few custom pieces to make it look like one. But I agree Grotsmasha and A Kvlt Ghost it isn't the best kit for converting. I'd go the Ven. Dread route if you want to convert and have multiple options. Link to comment https://bolterandchainsword.com/topic/263014-how-customizable-is-the-hellbrute/#findComment-3204406 Share on other sites More sharing options...
