IK Viper Posted October 11, 2012 Share Posted October 11, 2012 I usually run my SR with a Twl MM, Twl Las Can, and the BS Missiles, I take Hurricane Bolters if I get the chance. so the way I read it PotMS lets me shoot 5 weapon systems per turn (if i meet the requirements to use PotMS) so are BS Missiles counted as one big system, or 4 small systems, same question with the Hurricane Bolters, this has obvious application when fireing weapons but I also have this come up when I take a weapon destroyed result on the SR, do you count the whole set of missiles as one, and the H. Bolters as one, or are they different weapons... and if you count them as one for damage do you count them as one for weapons fired? The way I play is that each "hard point" is one system, meaning 2 missiles in one wing, 2 in the other, the 2 twin likned weapons and the 2 H. Bolters giving you 6 weapons total, is this sound? By this logic I should be able to fire all but one hard point every turn i qualify for PotMS (shooting no more than 2 missiles per turn and counting the 2 missiles as 2 of my total toward weapons fired) example: I fly on and nuke a vindi with my Twl Las/Twl MM/ and 2 BS Missiles for a total of 4 weapons fired, and then PotMS 1 H. Bolter into some Tacs... that seams to make sense to me, but the problem is that you are counting the missiles as 2 seperate systems here so when the SR takes a hit are they all still counted as 4 individual systems? Link to comment https://bolterandchainsword.com/topic/263080-stormraven-weapons-system-question/ Share on other sites More sharing options...
ServoBadger Posted October 11, 2012 Share Posted October 11, 2012 I count each Bloodstrike Missile and each Hurricane Bolter sponson as a separate weapon, for a total of eight weapons on the Stormraven before any missiles are fired, but that's just me. Link to comment https://bolterandchainsword.com/topic/263080-stormraven-weapons-system-question/#findComment-3204972 Share on other sites More sharing options...
IK Viper Posted October 11, 2012 Author Share Posted October 11, 2012 actually that makes alot of sense, it also helps against the weapon destoryed stuff, ... feel silly now I guess Link to comment https://bolterandchainsword.com/topic/263080-stormraven-weapons-system-question/#findComment-3204980 Share on other sites More sharing options...
Morticon Posted October 11, 2012 Share Posted October 11, 2012 Yupyup. The missiles are individual, as are the Hurricane Bolters. So you're looking at 8 different weapon systems. Any 5 of which we can fire with POTMS! Link to comment https://bolterandchainsword.com/topic/263080-stormraven-weapons-system-question/#findComment-3205038 Share on other sites More sharing options...
DominicJ Posted October 13, 2012 Share Posted October 13, 2012 I'm not sure that PotMS over rules two missiles per turn? Link to comment https://bolterandchainsword.com/topic/263080-stormraven-weapons-system-question/#findComment-3207124 Share on other sites More sharing options...
Morticon Posted October 13, 2012 Share Posted October 13, 2012 I'm not sure that PotMS over rules two missiles per turn? Missiles say a maximum of 2 missiles may be fired per turn. PotMS says: "the vehicle can fire one more weapon at its full ballistic skill than normally permitted." If we are normally permitted to firing 2, then 2+1 seems more than fair. Link to comment https://bolterandchainsword.com/topic/263080-stormraven-weapons-system-question/#findComment-3207240 Share on other sites More sharing options...
Jorre Posted October 16, 2012 Share Posted October 16, 2012 Ballz..... I forgot about potms. Been firing only 4 weapons per turn! Still very effective though! Link to comment https://bolterandchainsword.com/topic/263080-stormraven-weapons-system-question/#findComment-3209789 Share on other sites More sharing options...
