Sooo reading through the codex again I noticed that our juggernauts have the cavalry rule, but not the limitation of moving only 6". Am I reading this wrong?
Yupp!
5 spawns and 1 juggerlord = horrible unit to deal with.
Can't wait to try this, am currently trying to find a 5th spawn in my colection was sure I had one somewhere...
https://bolterandchainsword.com/topic/263171-our-juggers/#findComment-3206362
I'm going to give it a shot as well. I've had a twin claw Khorne Lord on a Jugger for a while now. I just need to bolter my Spawn collection up from the one I actually have.
Grab a box of 3 Juggers & Letters and your almost there. Grab 2 boxes and you have your Lord + 5 Spawns.
Cheers,
https://bolterandchainsword.com/topic/263171-our-juggers/#findComment-3206408
Cheers,
But if you still had the spawn bitz (they come with an excessive amount of arms, eyes and such) couldn't you just wad up some modeling putty and stick the various arms and stuff into it, and mount it on a 40mm base and call it done?
https://bolterandchainsword.com/topic/263171-our-juggers/#findComment-3206528
Cheers,
certainly
Just don't cheat yourself by not even trying to make it look cool.
https://bolterandchainsword.com/topic/263171-our-juggers/#findComment-3206586
It is a nice idea for a unit but remember that you can't take the Mark of Nurgle on the spawns, else the lord can't join them!
I don't understand? Dex not here so can't look it up but I don't remember any mixing marks probs apart from hate rule ie khorne vs. Slaanesh and nurgle vs tzeentch ?
https://bolterandchainsword.com/topic/263171-our-juggers/#findComment-3207007
An IC with one mark can't join a unit with a different mark. For reference it's written on the page with the marks.
https://bolterandchainsword.com/topic/263171-our-juggers/#findComment-3207034
he has all marks , so he cant join cult units , because he always has a mark different then the one the cult unit has . the rule doesnt ask you to check if you have a mark [it is perfectly legal to put a markless lord in to a cult unit . even if taking such lord makes little sense].
https://bolterandchainsword.com/topic/263171-our-juggers/#findComment-3207352
Wow, what an oversight! :cuss I can't believe that was intended, but it's absolutely the way the rules work. One more reason not to use Abby, I guess.
https://bolterandchainsword.com/topic/263171-our-juggers/#findComment-3207361
You're right, but I think there's a better way of looking at it. Don't think of Abaddon as having "all marks" - he doesn't. he has one mark - the Mark of Chaos Ascendant. This is a mark in his own right, so he can only join units with either no mark, or units with the Mark of Chaos Ascendant (of which there are none).
https://bolterandchainsword.com/topic/263171-our-juggers/#findComment-3207406
Yes and it feels retarded allready, now I have the codex and some lists ready but some things are made of pure unlogics.
https://bolterandchainsword.com/topic/263171-our-juggers/#findComment-3207432
The Juggerlord has become my new standard Warlord. Who needs Special Char's when we got proper Daemonic Steeds and ML(3) Sorcerers?
In addition to the Juggernaught, I run him with Seal of Corruption, Gift of Mutation and Axe of Blind Fury (I see many Terminators in my LSG.)
He's not really afraid of anything except for S10. Use unmarked Spawns or Khorne Bikes/Khorne Raptors as escort and call it a day.
https://bolterandchainsword.com/topic/263171-our-juggers/#findComment-3207498
huron gives infiltrate . this is a huge or rather HUGE buff to chaos armies , even a single infiltrating chaos unit can help a lot against other armies and on those 1/3 times you get 3 its a game winner . The utility he brings is for some builds or in some match ups more important then a challange lord . I'm not saying ax jugger lord is bad. he is awesome , but he still is a gav dex era warp time DP as game play goes.
https://bolterandchainsword.com/topic/263171-our-juggers/#findComment-3207714
It was a figure of speech. ;)
Also the Jugger can "hide" in units and get LoS, while the 5th Ed. DP only usually got shot to death asap.
https://bolterandchainsword.com/topic/263171-our-juggers/#findComment-3207723
only there was 2 of them , so one always got in to hth . same today one lords always makes it in to hth .
I can only speak for myself, but I only use one Lord. ML(3) Sorc's are to good to pass up on.
(We only play with 1 FoC below 3000 pts at my LGS.)
https://bolterandchainsword.com/topic/263171-our-juggers/#findComment-3207809
I'm getting curious about the Lord on juggernaut's performance on the table. It's obvious Huron is one of the most effective choices in the HQ section (if you roll 5-6 you infiltrate 3 units: that's a potential game changing event) but I can find a way to field both of them, especially when I play at 2000pts.
By the way do you have any suggestion on actually building the model? I was thinking about the fantasy chaos lord on juggernaut and add some bits to his armour (the CSM back pack, shoulder pads, if possible, etc) but the model is an old metal one.
I thought about it because it looks cooler then the "standard" daemons juggers (bloodcrushers and khorne herald, for example).
Any idea?
https://bolterandchainsword.com/topic/263171-our-juggers/#findComment-3207817
