Raptors equipment question
So i have built my new raptors with tank hunting in mind and given two member the melta gun.
In the codex entry it reads as following
Up to two raptors may replace their bolt pistol with a plasma pistol
Or take one of the following (list of specials)
Does this mean a raptor with melta gun keeps his bolt pistol and thus does not lose an attack for having 2 CCW?
https://bolterandchainsword.com/topic/263400-raptors-equipment-question/
It also makes the plasma pistol objectively worse than meltaguns on them. It costs five more points than a meltagun, for the same range, lower strength, lower ap, no melat rule, gets hot, and doesn't even give you an extra attack in close combat because raptors keep their pistols when they buy meltaguns.
It has the stupid effect of meaning that you could buy a melta gun, or pay 5 points more to replace your bolt pistol with a plasma pistol, a gun with worse stats, no armourbane, and that has the possibility of killing you. The best 5 points you could ever pay!
Yeah, for some reason, GW consistently overvalues plasma pistols.
I think that either someone on the design team uses plasma pistols too often, and yells BOOM HEADSHOT! every time they hit, or someone has shifted them over a column on the (mythical?) spreadsheet of what everything is worth pointswise based on weapon attributes.
