Vallejo Matt Varnish is Glossy?!
IronKobra
Hi All, I am just about finished with another model, but I am having problems with the Vallejo Matt Varnish.
Now I have put a layer of Vallejo Gloss down from an airbrush, waited for it to dry for a day or so, then applied a layer of matt, but I am finding the Matt varnish is still drying pretty glossy.
Now I have used this method before when I painted up a Gabriel Seth last year and it worked fine, so I'm a bit unsure as to why it's not having the desired effect this time around.
Anyone got any tips, like mixes with water or anything to get this Matt varnish to dry with a matt finish?
https://bolterandchainsword.com/topic/263437-vallejo-matt-varnish-is-glossy/
Shake it. Shake it until you hurt, then as long again. Vallejo paints tend to settle a bit.
Same for varnish?
Here is the model in question, you can see it is pretty dang glossy despite 2 coats of matt varnish from an airbrush
http://i847.photobucket.com/albums/ab36/IronKobra84/LtgSgtGloss.jpg
Thanks dude... I will try shaking the living crap out of it and try again tomorrow. I have been thinning it down, I tried first with water and it was still glossy, so tried with airbrush thinner and still no luck... but I will carry on and get it to work come hell or highwater! And when it does I'm going to try OSL on the powerfist for the first time
Matt varnish is finally cooperating, can nearly call this dude finished!
http://i847.photobucket.com/albums/ab36/IronKobra84/LtdSgtMatt.jpg
Thanks Winterdyne for the tip... I shook the hell out of the bottle and mixed it with water and is coming up much better ;)
