The Prophet Posted October 15, 2012 Share Posted October 15, 2012 So I was thinking maybe I would skip Huron and instead get this lovely fellow, for a combined outflank giver and Noise Marine troopmaker, as a birthday present for myself (I'm turning 30 in 1,5 hours). http://www.games-workshop.com/MEDIA_CustomProductCatalog/m1183603_99110201139_ChaosLordSlaaneshMain_445x319.jpg But what base should he have in 40k? Is it the kind of biker bases that comes with these ladies, or something else? http://www.games-workshop.com/MEDIA_CustomProductCatalog/m1290131a_99129915005_Seekers40k1MPPK_445x319.jpg How would you convert your Slaanesh Lord/Sorcerer on Steed? Link to comment https://bolterandchainsword.com/topic/263438-conversion-and-base-question/ Share on other sites More sharing options...
Phoros Posted October 15, 2012 Share Posted October 15, 2012 Same as with the Seekers, I'd imagine. Link to comment https://bolterandchainsword.com/topic/263438-conversion-and-base-question/#findComment-3209427 Share on other sites More sharing options...
Killax Posted October 15, 2012 Share Posted October 15, 2012 It's up to you. The base that fits "tight/perfectly" is the Terminator base, the Dread base is on the big side. Is there one in between? Cheers, Link to comment https://bolterandchainsword.com/topic/263438-conversion-and-base-question/#findComment-3209456 Share on other sites More sharing options...
The Prophet Posted October 16, 2012 Author Share Posted October 16, 2012 I'm a bit torn between the good looking circular ones (where the 40mm would look best imho) and the biker base that I guess 'should' be used, but I'm not sure on the later since it's not supplied with one for 40k. On the other hand, other steeds come with a biker base. Link to comment https://bolterandchainsword.com/topic/263438-conversion-and-base-question/#findComment-3209802 Share on other sites More sharing options...
Aidoneus Posted October 16, 2012 Share Posted October 16, 2012 Since there's no official model, I think you can do anything within reason. That's particularly true when you're doing it for aesthetic reasons. As long as you're not modeling for advantage (and it certainly sounds like you're not), knock yourself out. Link to comment https://bolterandchainsword.com/topic/263438-conversion-and-base-question/#findComment-3209832 Share on other sites More sharing options...
the jeske Posted October 16, 2012 Share Posted October 16, 2012 yep no official size . you should take the base from tervigon and model the mount to be the size of 2/3 of a land raider [but low , so he can hide behind walls. think chaos lord siting on a starfish with 8 arms . Link to comment https://bolterandchainsword.com/topic/263438-conversion-and-base-question/#findComment-3209845 Share on other sites More sharing options...
Aidoneus Posted October 16, 2012 Share Posted October 16, 2012 yep no official size . you should take the base from tervigon and model the mount to be the size of 2/3 of a land raider [but low , so he can hide behind walls. think chaos lord siting on a starfish with 8 arms . ^ That is a perfect example of "modeling for advantage," which is the one thing I think you are not allowed to do. :D Link to comment https://bolterandchainsword.com/topic/263438-conversion-and-base-question/#findComment-3209853 Share on other sites More sharing options...
Warbringer Posted October 23, 2012 Share Posted October 23, 2012 yep no official size . you should take the base from tervigon and model the mount to be the size of 2/3 of a land raider [but low , so he can hide behind walls. think chaos lord siting on a starfish with 8 arms . ^ That is a perfect example of "modeling for advantage," which is the one thing I think you are not allowed to do. <_< Or better yet use a dinner plate? ON a serious note, i would like at a 40mm base and then you can always make it part of a 60mm base so you can do a cool scenic but when you actually play its on a 40mm base? Link to comment https://bolterandchainsword.com/topic/263438-conversion-and-base-question/#findComment-3216965 Share on other sites More sharing options...
Hanska Posted October 24, 2012 Share Posted October 24, 2012 think chaos lord siting on a starfish with 8 arms . Never thought Jeske would make me laugh my bottom off. Link to comment https://bolterandchainsword.com/topic/263438-conversion-and-base-question/#findComment-3218567 Share on other sites More sharing options...
