Blood Pact Article?
[i'm unsure if this is even the right subforum for this thread. By all means move it if it isn't the right subforum.]
I'm wanting to follow an old example of making Blood Pact masks for guardsmen by using the daemonic turret-gargoyles that our Chaos tanks can use in the place of the usual gun-barrels.
I recall a Games Workshop article from the GW website awhile back that explained different Imperial Guard doctrines, one of those doctrines was the Blood Pact. Does anyone have a link to a PDF or something showing that article, or at least the image showing the Blood Pact?
I'll be using Shock Troops from the Wargames Factory: http://wargamesfactory.com/webstore/alien-...atcoat-troopers in anyone is curious about what models I'll be using.
https://bolterandchainsword.com/topic/263631-blood-pact-article/
Wow those look really nice. Xeraxen I've used those Greatcoat shock troops before and they are very good for your money. The heads don't really mix with the citadel guard kits so it takes a bit of converting or you can just use the shocktroops as they are.
