Bleached Bone Headaches
Rhetoricus
So ive based with bleached bone washed with thinned scorched brown and am in the process of re applying bleached bone.
I'm having similar problems to the ones I encountered when I used to try painting yellow straight onto black (poor coverage, streaks etc) only they seem weirdly exaggerated for some reason.
Has anybody else encountered this problem painting bone before? I consider myself a reasonable painter but this is driving me insane
Any help muchly appreciated.
Thanks guys.
https://bolterandchainsword.com/topic/264163-bleached-bone-headaches/
Bleached Bone is a bit of a bugger for that.
laying down a coat of Dheneb Stone over the Scorched Brown and then laying the Bleached Bone on top of that may sort out your woes :(
I use Dheneb Stone in place of Bleached Bone these days, purely because of the coverage issue.
+1 on the new colours - they give a more 'realistic' bone colour
new vs old
edit: worth noting this was a quick paint job to test the new range rather than being aplied with care.
chest eagles here are done a bit more carefully
no issues with any of the paints being to thin, even when watered down a bit they gave good coverage
If youre dead set on strict gw colors, then my only base coat recommendation is that base category ..zandri dust (i think that's the name) from there, gerring a good bleached bone is pretty simple. However, for my part i like the reaper master series bone triad, especially for hi quality work. For quantity work, well there i recomend that base (zandri dust, gw), then a sepia wash, then a reaper aged bone coat, and finally another sepia wash. The reaper polished bone can be used for final highlights after this, though i do not often find it necessary.
I might be able to pass a pic or two if wanted...
Edit: zandri dust is the base i have been working with...not ubshabti.
Yes please! post away. That would be most appreciated.
Thank you very much
Ok. I think this process flow should give you something to work with...
http://i1011.photobucket.com/albums/af231/shadowlords/WH40K/Bonearmor.jpg
Paints used: Zandri Dust (GW base color), Seraphim Sepia (GW shade color), and Aged Bone (Reaper Master Series Paint). Phase 2 is undiluted. Phase 4 is around 1:3 or 1:4 paint to water....i think....
Time per model is around 3-5 minutes depending. I have been working 15-20(ish) figures at a time with this, so my timing is more than a bit off.
A long way back i used to prime black, base coat with bubonic brown and then layer up to Bleachbone and then to white for extreme highlights
Nowadays i think you should use dheneb stone and then wash with sepia, afterwards layering up to BB and white for extreme highlights, afterwards giving a very dilluted wash of sepia.
Maybe have a look here: Fortress of the unforgiven
Marco
what look are you after (and on what type of model?) if you're set on using bleached bone, mix a middle colour up with a bit of your base layer in it, it will improve the coverage.
if you want quick & easy bone armour then rakarth flesh, mix gloss varnish & sepia, apply, soak up excess with a brush, palid flesh highlights & satin spray to kill the shine after.
Its for all the bone details on my IF termies (in my sig) I'm not set on a particular look, just trying to work with what I have. I do have dheneb stone available.
Your first comment has confused me slightly. Bleached Bone was my base layer so what would I be adding to this to improve coverage? I think my mistake may have been shading with scorched brown as opposed to Bestial. Although I do prefer the deeper shading that scorched provides it takes much more time and care working back up to bone.
Cheers Lorenzen, oh by the way did I ever get around to thanking you for suggesting gray primer? Well THANK YOU! I love it. Haven't looked back.
I like it. Can't see any reason why this wont work anyway so i'm gonna have a go. Making my method
1. BB base
2. SB shade
3 SB+BB first layar
4. BB second layar
5. BB+SW highlights
Too late for me to go back now cos steps 1 and 2 are done!
