spartan249 Posted October 26, 2012 Share Posted October 26, 2012 Here's something I've been wondering for a bit. Does an IC attached to a scoring unit count as a scoring model itself? Most references I'm finding only refer to units with the scoring characteristic, so I'm thinking that attached ICs also count as part of the scoring unit. Others disagree with me though. So is scoring status handled on a model basis or on a unit basis? Link to comment Share on other sites More sharing options...
Grey Mage Posted October 26, 2012 Share Posted October 26, 2012 Unit by Unit, and an IC counts as a member of the unit.... So I think youre right. Im not at my books at the moment however. Link to comment Share on other sites More sharing options...
spartan249 Posted October 26, 2012 Author Share Posted October 26, 2012 My detractors probably have a personal stake in this, as I'm using Draigo to pick up the relic T1. I don't know, I have a bias too, so I'm putting this question up for all to see. Link to comment Share on other sites More sharing options...
Seahawk Posted October 26, 2012 Share Posted October 26, 2012 Page 39: "While an Independent Character is part of a unit, he counts as part of the unit for all rules purposes..." So, Character + Scoring unit = Scoring Character. Yay! :) Now, how about the reverse? Immovable Object says "Your Warlord is a scoring unit..." I don't think so. Scoring Character + Unit =/= Scoring unit. Aww. :( Link to comment Share on other sites More sharing options...
Calnus Posted October 26, 2012 Share Posted October 26, 2012 In the case of Immovable Object, if the character model was within 3" , would it not still score? Or is that overridden by the IC rules upon joining a unit? I definitely would not say that the rest of the unit could be measured to for scoring purposes, but the scoring is usually done unit-by-unit vs. model-by-model, even though you alwasy measure to the closest model, whose traits match its unit. Link to comment Share on other sites More sharing options...
Seahawk Posted October 26, 2012 Share Posted October 26, 2012 It's overridden by the character joining the unit. Remember, "he counts as part of the unit for all rules purposes..." Counts as part of that unit. Is that unit a scoring one? If yes, then he scores too. Is it not a scoring unit? Then no he doesn't either. This is just one reason why I almost never use the Personal chart. :P Link to comment Share on other sites More sharing options...
Azatoth Posted October 26, 2012 Share Posted October 26, 2012 It's overridden by the character joining the unit. Remember, "he counts as part of the unit for all rules purposes..." Counts as part of that unit. Is that unit a scoring one? If yes, then he scores too. Is it not a scoring unit? Then no he doesn't either. This is just one reason why I almost never use the Personal chart. :P But if everybody in the nonscoring squad beside himself was killed he would be once more scoring, right? Link to comment Share on other sites More sharing options...
Seahawk Posted October 26, 2012 Share Posted October 26, 2012 Yep! It's only while he's joined that he loses his scoring status. Link to comment Share on other sites More sharing options...
Raeven Posted October 27, 2012 Share Posted October 27, 2012 I don't understand. Are they claiming that you can count victory points twice when an IC is attached to a scoring unit? Link to comment Share on other sites More sharing options...
Raeven Posted October 27, 2012 Share Posted October 27, 2012 It's overridden by the character joining the unit. Remember, "he counts as part of the unit for all rules purposes..." Counts as part of that unit. Is that unit a scoring one? If yes, then he scores too. Is it not a scoring unit? Then no he doesn't either. This is just one reason why I almost never use the Personal chart. :) I don't agree with your reasoning. Joining a unit doesn't disqualify the special rules that only the IC has, unless the rule specifically says so. There are also rules that get granted to the unit or IC, so long as one model in that unit has the rule. Fearless for example, when and IC joins a unit, grants fearless to the entire unit. If you look at the rule for controlling objectives, it says, "..if there is at least one model from one of your scoring units..." So, he may not grant the unit scoring status, but the unit doesn't disqualify his scoring status either. As long as the Scoring Warlord is within 3" of the objective, it's still a victory point added to your tally. Link to comment Share on other sites More sharing options...
Seahawk Posted October 27, 2012 Share Posted October 27, 2012 "All" is, well, all inclusive. If he is a member of a non-scoring unit, then he is exactly the same: non-scoring. Link to comment Share on other sites More sharing options...
Raeven Posted October 27, 2012 Share Posted October 27, 2012 If that is your argument, then when an IC joins a scoring unit the entire unit stops being scoring because that rule is not conferred. Either that, or scoring status remains unaffected and both the unit or the Warlord keeps the scoring status special rule regardless of join status. pg 39. Special rules "When an IC joins a unit, it might have different rules from those of the unit. Unless specified in the rule itself, the units special rules are not conferred upon the IC and the IC's special rules are not conferred upon the unit." Also, there are only 4 restrictions that prevent a normally scoring unit from scoring. Being joined or joining another unit is not listed among those restrictions. pg. 123. Link to comment Share on other sites More sharing options...
Seahawk Posted October 27, 2012 Share Posted October 27, 2012 "Scoring" isn't a special rule that the unit has. It's a mechanic of the game. Link to comment Share on other sites More sharing options...
Raeven Posted October 28, 2012 Share Posted October 28, 2012 Of which there are only 4 rules that exclude the unit from scoring. A scoring IC joining a unit is not one of those exclusions. Link to comment Share on other sites More sharing options...
