Gore Tutorial
I figured I'd post this here for all to benefit from, enjoy.
Step 1: Music
http://www.youtube.com/watch?v=Ch5zWkh04dM...ture=plpp_video
Here's what you'll need:
http://i1162.photobucket.com/albums/q532/mv8830/DSC00382.jpg
Start by applying red gore to the areas you want blood spatter on.
http://i1162.photobucket.com/albums/q532/mv8830/DSC00383.jpg
I recommend drybrushing it on for a more realistic spatter effect that doesn't look like a 5 year old took a red crayon to it.
http://i1162.photobucket.com/albums/q532/mv8830/DSC00384.jpg
http://i1162.photobucket.com/albums/q532/mv8830/DSC00386.jpg
Ensure you paint all the teeth on chainblades, remember these things are whirling, grinding, nasty pieces of machinery that are going to get pieces of people sprayed all around in their internal workings.
http://i1162.photobucket.com/albums/q532/mv8830/DSC00387.jpg
Then paint the point of impact on the chain blade, this is going to be where a limb or head was hacked into. Seeing as these weapons, when used against other Astartes, are only effective when they hit a joint. As far as chain axes go this is going to mean the entire head is usually the point of impact seeing as the have a shorter surface area than a sword. common sense applies.
http://i1162.photobucket.com/albums/q532/mv8830/DSC00388.jpg
http://i1162.photobucket.com/albums/q532/mv8830/DSC00389.jpg
http://i1162.photobucket.com/albums/q532/mv8830/DSC00390.jpg
Next make a 2:1 mix of Red Gore to Black, depending on how light or dark you want the gore to be you can tweak this mixture as you see fit.
http://i1162.photobucket.com/albums/q532/mv8830/DSC00391.jpg
http://i1162.photobucket.com/albums/q532/mv8830/DSC00392.jpg
this is the consistency you're going for.
http://i1162.photobucket.com/albums/q532/mv8830/DSC00393.jpg
Apply this to central points and areas of highest concentration. This means recesses, crevices, and areas where gore is likely to pool and build up.
http://i1162.photobucket.com/albums/q532/mv8830/DSC00394.jpg
http://i1162.photobucket.com/albums/q532/mv8830/DSC00397.jpg
http://i1162.photobucket.com/albums/q532/mv8830/DSC00398.jpg
On the Chainblade this means at the base of the teeth along the chain and at the point of impact.
http://i1162.photobucket.com/albums/q532/mv8830/DSC00396.jpg
http://i1162.photobucket.com/albums/q532/mv8830/DSC00399.jpg
Finally drop out a little gloss varnish
http://i1162.photobucket.com/albums/q532/mv8830/DSC00400.jpg
Apply the gloss coat to every fleck of blood, but don't get sloppy and get it on untouched armor otherwise the effect of glistening, wet gore is not as clear.
http://i1162.photobucket.com/albums/q532/mv8830/DSC00402.jpg
And voila! That's it, simple and effective.
http://i1162.photobucket.com/albums/q532/mv8830/DSC00403.jpg
http://i1162.photobucket.com/albums/q532/mv8830/DSC00076.jpg
Hope this helps all of you looking to walk the Crimson Path.
NOTE: A word of caution, less is more in the case of gore, don't make your guys look like the just took a blood soaked shower, apply common sense to the direction and placement of the spatters, if you need to, watch a few episodes of Dexter, you'll get the idea.
https://bolterandchainsword.com/topic/264434-gore-tutorial/
  • 1 month later...
