Weapons fire
Olis
Does anyone else mentally envisage Volkites firing energy 'blade' crescents? I see them as a bit like the muzzle flash from the bolters on the front of Rogue Trader:
Except it's the curve that leads the energy shot, rather than staying at the muzzle like in the picture.
What does everybody think? Do you envision it like this or like something else?
https://bolterandchainsword.com/topic/264742-weapons-fire/
They're mentioned in Brotherhood of the Storm, though I'll need to check and see if theres a specific description of them firing. I don't recall there having been one so far (I'm only part way through reading it, it did only show up yesterday :P).
Volkites?
A family of specialised, and advanced (read: difficult to produce and maintain, even in the more enlightened Pre-Heresy period), energy weapons that predated bolt weapons amongst the early Legions, was becoming rarer/extinct around the time of the Heresy.
They were introduced in the Horus Heresy - Book 1 - Betrayal from FW.
Edit - Ninja'd by Olisredan...
https://bolterandchainsword.com/topic/264742-weapons-fire/#findComment-3225921
There was a Rogue Trader era mini that had a 'hand flamer' like the one in the picture. The 25th anniversary figure was given a plasma pistol instead. Volkites seemed to be based on these early weapons.
As for the question in the OP, I could see conversion beamers having an expanding crescent discharge. Straight energy weapons like Volkites could be more like las fire - a straight line of energy that does whatever it's supposed to do when it hits the target.
https://bolterandchainsword.com/topic/264742-weapons-fire/#findComment-3226041
I see it a little differently.
I'm using the Volkite weapon on the Jetbike as a reference, but I see the teeth lighting up first with energy. These coalesce into the centre where they are discharged forward in a singular, unstable beam that fragments and burns on the target(s).
Where a Lasgun is a laser pointer (with a red beam), I see it as a thick yellow beam that does not have smooth "sides".
https://bolterandchainsword.com/topic/264742-weapons-fire/#findComment-3226337
that captain's wrist-mounted weapon (that changed into a plasma pistol on the new mini) looks awfully similar to a Volkite Serpenta now that i look at that picture again...
Agreed. It does look very similar indeed. In fact it was the basis of my mental image of a Volkite before I had seen any actual representations.
Interesting, a straight beam. A bit like the 'plasma' weapon in the picture, yes?
Nice description, it certainly gets the imagination going. Probably the best answer yet, if I'm to be honest. ;)
https://bolterandchainsword.com/topic/264742-weapons-fire/#findComment-3226492
Brotherhood of the Storm refers to a 'volkite culverin' as an "...esoteric beam-weapon...". The book also mentions "...neon-bright spears of energy...", although that could be referring to lascannons instead. Not sure if that shed any light, but it's all the information I have on them until my copy of Betrayer arrives.
https://bolterandchainsword.com/topic/264742-weapons-fire/#findComment-3227264
Not really sure what plasma looks like. It is bolts of "plasma" but I suppose each bolt looks like a really long comet.
Nice description, it certainly gets the imagination going. Probably the best answer yet, if I'm to be honest. :)
Thick yellow lightning?
https://bolterandchainsword.com/topic/264742-weapons-fire/#findComment-3227434
