Clear acrylic rod
Seahawk
So I'm in the process of building flying stands for me Hell Blades and was thinking about clear acrylic rod as being the best and cheapest option. Now, the question is, what thickness do I go with? I want something sturdy and not going to bend with the slight weight of the Hell Blade (it's probably lighter than a Heldrake). I was thinking 1/2" would work best while being nicely size for construction work. If anyone has worked with this stuff before, would that size be alright?
https://bolterandchainsword.com/topic/264923-clear-acrylic-rod/
Hi,
Just made the flying bases for my Stormtalons and used 5.5mm acrylic rod for those and it does not flex at all on the same height as the GW stand, For my Stormeagle I used 10mm and Thunderhawk 12mm which is around 1/2inch so that is more than enough for Hellblades.
Hope it helps...
