Snejk Posted November 4, 2012 Share Posted November 4, 2012 Hello! I have never been a big fan of the Marine bikers, be it loyalists or traitors, so I have always looked for something to replace them bikes and yesterday I thought i had found what i was looking for - Slaanesh Hellstriders. So I went and bought a box of them bad boys and realised the saddles look way to small and will need some adjustment. It looks like there is a possibility to to use the lower body (Hips and thighs) off the dudes riding the beasts, and just add the lower legs and torso from a Marine. Has anyone else thought of using the Hellstrider miniis as mounts for CSM? And how have you modified the saddle and or other parts? Link to comment https://bolterandchainsword.com/topic/264972-hellstrider-bikers/ Share on other sites More sharing options...
redmapa Posted November 5, 2012 Share Posted November 5, 2012 what you could do to make them fit is cut every section of the marine's legs and basically re-pose them to make them fit and/or sculpt a bigger saddle..either way I think its a great idea.. Link to comment https://bolterandchainsword.com/topic/264972-hellstrider-bikers/#findComment-3229663 Share on other sites More sharing options...
Warsmith Aznable Posted November 5, 2012 Share Posted November 5, 2012 what you could do to make them fit is cut every section of the marine's legs and basically re-pose them to make them fit and/or sculpt a bigger saddle..either way I think its a great idea.. Warhammer Fantasy Battles Knights of Chaos legs bits. Much easier to convert than Space Marine legs. Link to comment https://bolterandchainsword.com/topic/264972-hellstrider-bikers/#findComment-3229672 Share on other sites More sharing options...
lhg033 Posted November 5, 2012 Share Posted November 5, 2012 Warhammer Fantasy Battles Knights of Chaos legs bits. Much easier to convert than Space Marine legs. this - with doghouse style gs on the legs may look pretty impressive. my only concern is that the hellstriders might look a little slight under a marine - then again i only have the old metal seeker models as a comparison for the steeds so the new hellstriders may be better suited Link to comment https://bolterandchainsword.com/topic/264972-hellstrider-bikers/#findComment-3229878 Share on other sites More sharing options...
Snejk Posted November 6, 2012 Author Share Posted November 6, 2012 Warhammer Fantasy Battles Knights of Chaos legs bits. Much easier to convert than Space Marine legs. this - with doghouse style gs on the legs may look pretty impressive. my only concern is that the hellstriders might look a little slight under a marine - then again i only have the old metal seeker models as a comparison for the steeds so the new hellstriders may be better suited The height of the hellstrider looks OK. But the mini it self might as you say look a little slight in comparison when the Marine mounts the little feller. What is doghouse style gs? Marine and hellstrider size comparison: Link to comment https://bolterandchainsword.com/topic/264972-hellstrider-bikers/#findComment-3231500 Share on other sites More sharing options...
lhg033 Posted November 7, 2012 Share Posted November 7, 2012 doghouse gothic marines it uses the WFB chaos legs so my be a good starting point to alter the ones that come with the hellstrider. Link to comment https://bolterandchainsword.com/topic/264972-hellstrider-bikers/#findComment-3231846 Share on other sites More sharing options...
