DasPanzerIstUber Posted November 5, 2012 Share Posted November 5, 2012 I've been busy converting a Land Raider with weapon switch options and the Helios variant is now a possibility. I was wondering how Power of the Machine Spirit works with this tank, given it has both heavy and ordnance weapons. My ideal scenario is the ability to fire both of the lascannons at one target with full BS then fire the Whirlwind launcher at another using the PotMS but I have a feeling GW knows this and will try to prevent it with "the rules". :cuss Anyway enough whinging let's get into rules questions! Would the lascannons be forced to make snapshots because an ordnance weapon has been fired? Or would they be unaffected and fire at full BS because the Whirlwind launcher is being fired afterwards using PotMS? I just want to be crystal clear on these rules before I roll this beast onto the field! B) Link to comment Share on other sites More sharing options...
Leonaides Posted November 5, 2012 Share Posted November 5, 2012 All fire at the same time, so its snap-shots for you I believe... Link to comment Share on other sites More sharing options...
DasPanzerIstUber Posted November 5, 2012 Author Share Posted November 5, 2012 Yep thought that might be the case. Thanks for the help. :) Link to comment Share on other sites More sharing options...
DasPanzerIstUber Posted November 10, 2012 Author Share Posted November 10, 2012 Hmm got another one for you. Is a Helios able to move at Cruising Speed and fire the Whirlwind Launcher with PotMS, while snap firing the Lascannons? I've been looking unsuccessfully for anything that says you are unable to fire barrage or ordnance while moving. Link to comment Share on other sites More sharing options...
