light Mech
Brom MKIV
Grey Knights and Space Wolves can do just as well with Razorspam as we can, if not better in most respects. Also Imperial Guard with their cheap chimeras are another contender.
I dropped my Razors because I was tired of giving up the first blood secondary objective when I went second. I'm thinking about putting them back in but not using them as blockers up front at the beginning but zooming out of some kind of cover.
I never went full mech, I always did a hybrid of Razors blocking for jumpers behind them with a priest occupying the 6th seat so I didn't have to pay for the jump pack.
https://bolterandchainsword.com/topic/265216-light-mech/#findComment-3231724
Light Mech would be accomplished with using Baal Predators/Vindicators/Whirlwinds now with some support froma librarian dreadnought.
I have come accustomed to using two baal predators with a librarian dreadnought for shield of sanguinius. Then leaving a whirlwind in the back field to drop some ignore cover on pesky rangers/pathfinders/scouts.
https://bolterandchainsword.com/topic/265216-light-mech/#findComment-3231725
The core of my lists is 2 Ravens, 2 Baals and 3 Attack Bikes. I have sometimes included a TLLC Razorback as well. Some may argue that ravens are not "light" but if light means fast mobile and hard hitting then they certainly are "light" mech. Overall they have performed well. The bikes are very in your face and expected to either take out a high value target and slow movement or at the minimum absorb shooting that I dont want directed on my jumpers in the first turn. When the Baals and Ravens turn up I usually start moving troops around the board. I try to co-ordinate assaults from the jumpers with the vehicles shooting. In the last game against a very heavy mech ravenguard list I used the bikes as distraction hide my troops till the Ravens hit the board then moved everything up. On dawn of war setup bringing Ravens in from opposite ends of the short edges removes cover and allows the Ravens to shoot up anything the other Raven might have missed.
https://bolterandchainsword.com/topic/265216-light-mech/#findComment-3231760
I'd say Grey Knights win the 'best at' Light Mech and SW edge out BA out too.
5 GK Strike Squad: 4 Force Swords, 4 Stormbolters, 1 Psycannon and TLHB Razorback w/Psybolts = 160pts.
5 SW Grey Hunters: 5 BP-CCW, 4 Bolters, 1 Plasmagun and TLPG-LC Razorback = 160pts.
5 BA Assault Squad: 4 BP-CCW, 1 Flamer and TLPG-LC Razorback = 160pts.
Numbers like this mean if you play only Light Mech then you shouldn't use Blood Angels. Now HEAVY Mech, that's a totally different story! Did you know that currently in the US Army, a Mechanized Infantry Battalion uses 2 Companies of Abrams Battle Tanks organically alongside 2 Companies of Bradley APCs? Because the two complement each others' weaknesses in combined arms fighting.
So basically, I feel BA need to leave pure-AV11 spam to the codicies who are better at it. We should focus on the AV13-AV11 combination! Nobody does that better than us, IMO.
https://bolterandchainsword.com/topic/265216-light-mech/#findComment-3231765
How do you loadout your Baal's and Raven Drunken Angel? Heavy Bolters and Hurricane Bolters on everything? Is the rest of your list entirely jump infantry?
I run a heavy Baal using TLAC's and heavy bolter sponsons, a light Baal bare with just a TLAC, both have dozer blades. The Ravens are run with TLMM, TLAC and hurricane bolters. I dont put anything in the Ravens. For the rest I usually take a libby with 2 RAS squads+double meltaguns a single priest and a counter charge unit like DC or SG. Everything is jumpers. If points allow I add a 3rd RAS. I started using scouts and an aegis defence line with coms link to ensure the Baals and Ravens got a re-roll on reserves but stopped. The scouts are not really my kind of game and have been very boring and lack lustre so now I just slam the defence line down and leave a troop or combat squad near it to operate the coms link. The coms link is the key part of my game just one turn of Raven shooting on 2nd turn instead of 3rd ensures I keep the 2 RAS squads alive and combat effective. The firepower of those 2 Ravens screaming across the board 24-30 inches 2nd turn is awesome. If the baals are on the board giving cover on the jumper advance fine, but combine the 2 Baals on outflank with the Ravens and you have a shooty 2nd turn alpha strike that smacks rear armour beautifully. The bikes are usually dead by 3rd but if they have taken a land raider or some nasty template thing out they have done their job.
https://bolterandchainsword.com/topic/265216-light-mech/#findComment-3231787
I have never ran a mechanical list, beyond a solitary rhino.
However, i have fought them.
The problem they usually have, is lack of numbers.
Very roughly, if you shoot a razor with three rockets, two will hit, one will pen and it will be immobilized for a turn.
Three rockets isn't a lot, but it stops a razor dead.
My shoot lists can pin four razors with ease.
If you want light mech, you need something else as well.
Lots of it
stun locking four razors is one thing, six or eight is quite another.
Heavy armour
it takes twice as many rockets to glance a13
simply over match the enemy at capability
bigger threats.
Ten dc in a pod.
No one is going to shoot your tanks when you have dc in their lines
https://bolterandchainsword.com/topic/265216-light-mech/#findComment-3232109
1+1, MSU Razors is no longer what it was. However hiding behind Av13, may provide some tricks.
So what ? BA are able to pin 4 heavy weapon team/tank with ease too.
There is one thing that BA can do better than others with a few Tacticals : Reserving Rhinos.
In reserve, they don't give away First blood.
While reserve, the opposing heavy weapons are wasted shooting your foot sloggers.
While reserve, the opposing heavy weapons should die to your firepower
When they comes from reserves, they give cover 24" from your endzone.
Once opposing AT is gone, not much should stop your healthier unit to claim 1VP for surviving in ennemy lines.
Food for thoughts, those tricks can't be easily dismissed at 105 points (7% of a list).
https://bolterandchainsword.com/topic/265216-light-mech/#findComment-3232140
So what? BA are able to pin 4 heavy weapon team/tank with ease too.
So what?
Because its very easy for a moderately shootie army to stun four razorbacks, its a very bad idea to base your strategy on having four razorbacks with freedom of movement.
Light transports are prime targets because they are brilliantly effective tools to use, and relatively easy to destroy
Except in special circustances, I'd argue you should always pop transports as a priority.
If you want to use transports you need
so many that enough survive the inevitable losses (so 6, 8, 10)
Heavily Armored enough to survive the shooting (So raiders)
Special Circustances (so podded death company or some other sort of Turn One mayhem)
Or as CAG brilliantly suggests (cough stole from me cough)
Combine All Three and take 6 razorbacks and 6 predators :down:
https://bolterandchainsword.com/topic/265216-light-mech/#findComment-3232194
Just ordered three razors and two more battle forces.
Three assault squads in bolterbacks
two tactical squads in rhino
rec, priest, hammernators in a crusader.
Might change that to assaults in rhino and tac in bolterbacks.
Obviously won't be protesting this Tuesday, but next perhaps, anyone awaiting a dantewing test is going to be waiting a lot longer.
https://bolterandchainsword.com/topic/265216-light-mech/#findComment-3232908
Combine All Three and take 6 razorbacks and 6 predators :)
or add even more high AV targets instead of maxing out razorbacks :)
Unfortunately for us the AV13 spam isn't as good as it used to be.
https://bolterandchainsword.com/topic/265216-light-mech/#findComment-3232920
Couldn't agree more. I often use 4 preds (2 Autolas, 2 Dakka Baals) and varying amounts of mechanised troops (Assaults in Razors, Tacs in Rhinos). The transports full of marines seem to be almost invisible to most opponents when they're looking at a bunch of predators. Stick down the transports by themselves and they're wiped out post haste.
https://bolterandchainsword.com/topic/265216-light-mech/#findComment-3232925
Combine All Three and take 6 razorbacks and 6 predators :D
Raiders instead of Razors is a lot more points, and I ordered razors :(
DomJ: I would strongly recommend you get some assault cannons from trades/bitz sites to convert the bolterbacks to assbacks. The 105 pts expenditure is WELL worth it.
I've got three razors coming, I assume they come with asscannons?
https://bolterandchainsword.com/topic/265216-light-mech/#findComment-3233171
Nope. The Razorback sprue contains twin heavy bolters and twin lascannons. If you want any other options, you're looking at having to convert (heavy flamers, las-plas) or order bits (Land Raiders have a twin assault cannon turret that's the right size for Razorbacks).
https://bolterandchainsword.com/topic/265216-light-mech/#findComment-3233175
They don't, unfortunately. Twin heavy bolters, or twin las.
Actually, now that I think of it, grab some plasmaguns and convert twin las into las/plas. It's also a pretty easy conversion: chop off one of the lascannon barrels and glue two plasmaguns there. BA plasmabacks are the new sex.
https://bolterandchainsword.com/topic/265216-light-mech/#findComment-3233177
Sadly not. THey come with HBs and Twin-las only.
https://bolterandchainsword.com/topic/265216-light-mech/#findComment-3233183
