Shiny paint
I am painting some miscellaneous bits for my army. I don't normally paint, but I'm decent enough to touch up broken bits or paint an occasional simple weapon.
The primary color is Mechrite Red (It's called Mephiston Red now, but I have an old pot). I noticed that the bits that I painted, while looking decent, also ended up quite glossy. The rest of my (commissioned) army is not glossy at all. I'm hoping varnish would help bring the gloss down, but I can't help wondering why this would happen and how I can avoid glossy-looking finish. Is it my technique or is it something about the paint?
https://bolterandchainsword.com/topic/265236-shiny-paint/
Most likely the paint.
Is there any residue lodged in the bottle or has any of the layers 'split' / separated?
Did you shake the pot properly before using it?
I often find that even though a GW pot looks fine on the outside, you need to shake them well before use to keep the paint intact.
https://bolterandchainsword.com/topic/265236-shiny-paint/#findComment-3231909
One of the reasons I can think of is that you didn't shake the paint pot well enough. With some paints, especially the washes, you need to shake the pot for at least a minute or two. Otherwise the result might end up a bit glossy.
What I would suggest is shake the pot Mechrite Red for a good two minutes, and paint over the same (glossy) parts again. This should leave you with a matt finish, as it is supposed to look.
https://bolterandchainsword.com/topic/265236-shiny-paint/#findComment-3231910
I admit I thought at first that you two were joking (two minutes???) but did it anyway and shook the living hell out of that pot. And it made a world of difference. THANK YOU!
Maybe while you're at it you can teach me how to properly use Griffon Gold?
https://bolterandchainsword.com/topic/265236-shiny-paint/#findComment-3231919
If I remember rightly, Mechrite can dry a bit glossy. If the person who painted your minis used a matt varnish, then any slightly satin or glossy paints will contrast with a matt finish.
I'd just paint some matt varnish over the areas you've touched up. Vallejo do a good range of gloss, satin and matt varnishes.
https://bolterandchainsword.com/topic/265236-shiny-paint/#findComment-3231925
