Iron Warriors 1850
Hi guys , this is my idea of iron warrior army list. ^^ I hope you like it
Praetor, iron halo, paragon blade ; rite of war -> pride of the legion 150
Legion Veteran Tactical Squad, 10men, 2 Missile Laucher 250
Legion Terminator Squad, 10 men, Catafracti armours, 8 power fists, 2 chainfists; sergeant with grenade harness 395
1 Dreadnought Contemptor, 2 Twin-linked Lascannons , Carapace-mounted Havoc Launcher 240
Spartan Assault Tank 295
9 Legion Devastator Squad, 9 missile laucher, augury scanner 265
What do you think ??
https://bolterandchainsword.com/topic/265349-iron-warriors-1850/
where does the praetor go? and what does he do for you besides making vets (expensive) troops? a specialized centurion might be the better option.
lots of melee termis in a spartan are good, but fists on all is propably overkill. axes will do. if you take a spartan, give it ceramite, maybe even flare shields.
missle on the vets imply they just stand an shoot? what veteran skill do they have? maybe tacs will give you more flexibility and boots on the ground?
I'd add flakk and hardened armor to the heavy support squad, both is a steal. aegis recommended.
remember nothing has ATSKNF, so vexillae are a good idea.
I think it is very fragile and static. if your deathstar doesn't deliver, the rest of your army dies very quickly. also, IW without artillery? :)
I think it is very fragile and static. if your deathstar doesn't deliver, the rest of your army dies very quickly. also, IW without artillery? :mellow:
The ceramite armour for the spartan ! i have forgot it !.
i think the preator is the stronger charachter between the hero. Other one which i like ,may be the Centuiorn Forge Lord, with conversion beamer and jetbike, but i like the ideas of the veteran like troop. What type of centurion do you suggest me ??
Tha legionn veterans have Tank Hunters ^^
i don' like aegis. the are much terrain in the table, where occult the units, why pay points for it
a siege breaker with the heavy support squad wrecks everything, let him man an icarus behind the aegis. a master of sinlas will unleash hell all by himself. a vigilator outflanks anything. a forge lord with hammer, cataphractii TDA and familiar is a beast in CC, techmarine coven with beamers will do. vets are nice, but not numerous and with missle will not be mobile enough to get mission objectives - you need boots on the ground more than 2 krak missles!
Oki, i have modified with your helps. My ideas is to have a good force fot shoot, the support Squad inside the Achille with the techmarine, and terminators inside the Spartan for intercept the enemy's unit which arrive in my table side
-Siege Breaker 90
-Techmarine, combiweapon 60
-Apothecary, augury scanner 50
-Terminator Squad, 6 men, 4 power fists
-Tactical Squad, 13 men vexilla 190
-Tactical Squad, 10 men, 150
-Support marine, 5 men, 4plasma 160
-Land raider Achille 300
-Spartan, ceramite armour 315
-2x Medusa 310
nasty! :)
I think the siege breaker is 85, but should get meltabombs anyway. Maybe the spartan/achilles could be downgraded into phobos pattern to get some pts for him and/or some more tactical marines?
the techmarine is always a good choice. inside an achilles, the tank is practically indestructable. offensively, he doesn't bring much more than another support marine, through. him or +5 marines?
pointswise, an achilles is another support squad with another centurion and 2 rhinos!
tactically, you could run the tacs behind your LRs for LOS-blocking. that leaves your artillery open, unfortunately, but having a spartan with TDAs inside babysitting maybe overkill.
cool and fluffy, alltogether!
  • 5 weeks later...
