Word Bearers Grey?
Emperor's Furor
My a suggestion - try Abaddon Black base, Skavenblight Dinge main colour (black lining, i.e. leave black visible at joins between armour plates and in the deepest recesses of the model), sparse highlighting with Eshin Grey, final highlight (edging and high points) with either Stormvermin Fur, Dawnstone or Administratum Grey depending on how bright you want things to look.
Thats just off the top of my head, but it should provide a reasonably decent scheme without needing to do too much, if any, blending (meaning it will be easily reproducible).
Edit- It'll also give more depth than using a single shade.
I'm thinking of going with stormvermin grey with a black wash and highlighted with codex grey?
What do you think the trim of the Word Bearers pre heresy is? I was thinking it would either bright silver or gold.
Also considering inscribing the armour if I do decide to go with them, just not sure if I should wait for when they come out in the next book. I'm a little worried they won't have the crusade era shoulder pads.
Use Army Painter Uniform Grey Primer and do your prime and basecost in one :blink:
bad idea. uniform grey is a very very light grey when dry. its lighter than any final highlight grey most painters use on their models.
Not in my experience: it's been a mid-grey when I've used it, but each to their own. You're not using hyperbole are you as I can't see it being lighter than grey highlights.
Even so, one can tone it down with washes or glazes.
I love unique models, especially old one, things you don't tend to see that add a bit of spice to armies and I thought this one would quite cool in word bearers crusade force. Atm I'm contemplating an Ultramarine force, but if this turns out any good, then I may have to reconsider.
