Rhino Construction
Jakbal
Just have a good session of dry assembly (without glue) it's nota highly complex kit and won't fit correctly if put together the wrong way!
Each track has an inner and outer side, use the floor to attach them and the put the roof on. You can keep the internal wall (with the Bolter & TV screen) for the bits box if you like.
