Warmammer Posted November 16, 2012 Share Posted November 16, 2012 how would i convert them into normal bikers Link to comment https://bolterandchainsword.com/topic/265928-dv-bikers/ Share on other sites More sharing options...
Messor Posted November 16, 2012 Share Posted November 16, 2012 Shave off the icons, for a start. As for the rest, I clipped off the wings on the back, but left the shafts, just cuz, but I imagine the whole thing can come off pretty clean. What other parts are you worried about? Link to comment https://bolterandchainsword.com/topic/265928-dv-bikers/#findComment-3239476 Share on other sites More sharing options...
Hymirl Posted November 16, 2012 Share Posted November 16, 2012 Shaving off the ravenwing icons is fairly easy, the flagpoles cut off pretty nearly too if you're careful. A little selective trimming on the front wheelarch can put it straight instead of having a beak like shape. The biggest problem is the eagle on the front of the handlebars. I had a couple of regular bike parts left over from character models which had used the metal chaplain parts so I could trade the end wing parts for vanillia versions. They look pretty standard now. As I was mixing them into a load of regular bikes I didn't want them to stand out too much. Alternatively the extra bling makes for good HQ character bikes, or you could or just cut off the wing parts and make a simple straight finish from plasticard similar to GWs scout bikes. A torso swap is pretty easy on these guys, and probably recommended for the sarge unless you want to look 'robey'... Link to comment https://bolterandchainsword.com/topic/265928-dv-bikers/#findComment-3239624 Share on other sites More sharing options...
