Not sure if anyone outright sells D36, but I can tell you such a many-sided die is a pain to use anyway. If it lands on even a slightly uneven surface you can't really tell what number is actually on top. Plus comparing a result of 1-36 to a table that's not numbered for it (and thus you'd have to make your own for quick reference) makes it seems more trouble than it's worth.
https://bolterandchainsword.com/topic/266112-boon-dice/#findComment-3241377
Since I own a good many different dice I can tell you that any die over a d20 is very hard to read. I own a d100 and never use it due to the fact that it's sides are so small making the actual number difficult to read. I know I have some more unusual numbered dice but can't remember what they are since I never use them for the same reason.
https://bolterandchainsword.com/topic/266112-boon-dice/#findComment-3241472
