Inquisitor Eisenhorn Posted November 24, 2012 Share Posted November 24, 2012 Are plastic terminator heads and tactical heads fully interchangeable or do you need to file them down a bit to fit a tactical torso? Sorry for such a silly question--I've never bought a plastic terminator! Link to comment https://bolterandchainsword.com/topic/266450-terminator-heads/ Share on other sites More sharing options...
Da Once & Future Git Posted November 24, 2012 Share Posted November 24, 2012 Actually they are completely different... the normal tactical head is joined to the body at the neck whereas the termie helmet is attached at the back (as the torso continues above the head). I've put the the tactical heads into termies and had to do a fair bit of cutting & filing to make it fit... Not sure if you could go the other way. Hope this helps! Link to comment https://bolterandchainsword.com/topic/266450-terminator-heads/#findComment-3245592 Share on other sites More sharing options...
Valkyrion Posted November 24, 2012 Share Posted November 24, 2012 You'd struggle getting a terminator head to fit a power armour torso far more than the other way around. On a power armour head you could pretty much get away with just filing down the bump under his head, to put a terminator head on a power armour torso you'd need to file down the bump from the back and make a bump on the bottom, but I don't think it'd look right in any case. Link to comment https://bolterandchainsword.com/topic/266450-terminator-heads/#findComment-3245626 Share on other sites More sharing options...
Grotsmasha Posted November 24, 2012 Share Posted November 24, 2012 Unless of course you're talking about unarmoured heads, then they are completely interchangable. GK termi ones fit, but are noticably larger. Cheers, Jono Link to comment https://bolterandchainsword.com/topic/266450-terminator-heads/#findComment-3245735 Share on other sites More sharing options...
Kastor Krieg Posted November 24, 2012 Share Posted November 24, 2012 Nah, I've put a CSM termie head on a CSM pa body, even with the "tusks", gave him some horns too, made a "termie" Sorcerer out of him. Everything fit just fine, minor filing at the back and whammo. Some pics later on, if I manage and remember to ^_^ Link to comment https://bolterandchainsword.com/topic/266450-terminator-heads/#findComment-3245783 Share on other sites More sharing options...
Inquisitor Eisenhorn Posted November 24, 2012 Author Share Posted November 24, 2012 God I'm so stupid I should have specified, I meant the non helmet heads. So for example if you use the bare heads for wolf guard terminators on grey hunters there is no problem? Link to comment https://bolterandchainsword.com/topic/266450-terminator-heads/#findComment-3245785 Share on other sites More sharing options...
Grotsmasha Posted November 24, 2012 Share Posted November 24, 2012 God I'm so stupid I should have specified, I meant the non helmet heads. So for example if you use the bare heads for wolf guard terminators on grey hunters there is no problem? Yep, they'll fit right in. iirc, they are a smidge larger, but GWs scale is all over the place anyway Link to comment https://bolterandchainsword.com/topic/266450-terminator-heads/#findComment-3245804 Share on other sites More sharing options...
