saadeath Posted November 24, 2012 Share Posted November 24, 2012 Simple question, does simple green go bad after use? As in, if I soak some models, how long will it last after? If I keep it in a container will it still be good for awhile? Link to comment https://bolterandchainsword.com/topic/266492-simple-green/ Share on other sites More sharing options...
GumbaFish Posted November 25, 2012 Share Posted November 25, 2012 I'm not sure of an exact answer but you can use it multiple times. I have had the same jar strip multiple goes of miniatures, if it gets really full of loose paint I run it through a coffee filter and pour in some more and use it again. Worst case is try it after it sits a while and if it doesnt work soak them in some fresher stuff. I usually found once it started to lighten up in color it tended to loose some of its strength for stripping. Link to comment https://bolterandchainsword.com/topic/266492-simple-green/#findComment-3246106 Share on other sites More sharing options...
