How to Make simple Space Wolves: Wolf Standards
xPeRt
How to Make simple but effective Space Wolves: Wolf Standards.
Hey guy xPeRt here with a simple but effective way to get those Wolf Standards on the Field.
Things you will need:
Tools:
Hobby Knife
Hobby Drill w/ bit to match the size of the rod
Pinning Rod of appropriate size
Glue (here you can use what you want, but I prefer CA)
http://i130.photobucket.com/albums/p278/threedguru/WH40K/Space%20wolves%20Wolf%20Standard/th_20121126_134948_zps6b7eb8c4.jpg
Bits:
Grey Knight Nemesis Warding Staff
http://i130.photobucket.com/albums/p278/threedguru/WH40K/Space%20wolves%20Wolf%20Standard/th_gkstaff_zpsa653bd60.jpg
Space Wolves Backpack banner
http://i130.photobucket.com/albums/p278/threedguru/WH40K/Space%20wolves%20Wolf%20Standard/th_spacewolvespackbannerlarge_zps2daa577e.jpg
Space Wolves right arm with bolt pistol
http://i130.photobucket.com/albums/p278/threedguru/WH40K/Space%20wolves%20Wolf%20Standard/th_space_wolves_pack_weapon_bolt_pisto_zps1d491793.jpg
Instructions:
First and foremost. I do not have pictures of each step but I do have illustrations.
Step 1:
Cut the Pistol from the arm and file down the wrist to have a smooth surface to drill and pin. Cut a small piece of pinning rod to go into the hole you drill and glue.
http://i130.photobucket.com/albums/p278/threedguru/WH40K/Space%20wolves%20Wolf%20Standard/th_space_wolves_pack_weapon_bolt_pistol_arm_right_a_zpscce892a2.jpg
Step 2:
Cut the head of the staff off, and the bottom. Here you will need to measure how long you want the banner pole to be and cut off the appropriate amount. Drip and pin all the pieces together.
http://i130.photobucket.com/albums/p278/threedguru/WH40K/Space%20wolves%20Wolf%20Standard/th_nemesis-warding-staff-grey-knight_zps0d7b6feb.jpg
Step 3:
Cut off the bottom of the pack banner and drill a hole for a pin.
http://i130.photobucket.com/albums/p278/threedguru/WH40K/Space%20wolves%20Wolf%20Standard/th_space_wolves_pack_banner_large_zpsda275a06.jpg
Step 4:
Mock everything up before you glue, make any adjustments and then glue for final assembly.
If you did everything right it should end up looking like this:
http://i130.photobucket.com/albums/p278/threedguru/WH40K/Space%20wolves%20Wolf%20Standard/th_20121126_134154_zps8cf62c6a.jpg
http://i130.photobucket.com/albums/p278/threedguru/WH40K/Space%20wolves%20Wolf%20Standard/th_20121126_134141_zps8a4e294c.jpg
Hope Everyone Enjoys the Tutorial.
http://i130.photobucket.com/albums/p278/threedguru/WH40K/Space%20wolves%20Wolf%20Standard/20121126_145054_zps7d22080b.jpg
  • 2 months later...
