Alternate Models for DCA and Crusaders
saffo
I was trying to find a cheap way to get the models I need for power axes for my DCA squad and the crusaders to boot. I came across these models and would certainly make sure they were based on a round base. I am also going to mod the shields for the crusaders so they are not chaos emblems.
DCA: http://www.games-workshop.com/gws/catalog/...Id=prod1500396a
Crusaders:
http://www.games-workshop.com/gws/catalog/...dId=prod1040519
or
http://www.games-workshop.com/gws/catalog/...Id=prod1500501a
What are your thoughts and what more do you think I would need to do to make these viable for a 40k tournament?
Thanks!
I like the Dunlending Warriors...the Warriors of Chaos have Chaos markings all over them though, which won't do for an Imperial Force. :) Unless you're going for traitors, of course. Lots of conversion work there otherwise.
I caution you against using Dwarves for DCA or...anything, if only because of the incredible amount of overhead involved with Dwarves in 40k. (I.E. they explicitly do not exist and were allegedly retcon'd out of existence.) But, at the end of the day, it's your army. If you think you'd enjoy painting them and they'd fit your style, don't hold back.
I've used "repentant" Chaos Warriors with GKT heads as Crusaders before. The Dunlending Warriors also look like they'd work pretty well, with suitable Inquisition heraldry attached.
For DCA the Dark Eldar Wyches are pretty easy to convert. Each one comes with a knife or sword, and the pistols aren't hard to replace with a cut-down GK falchion, force sword, or even halberd (for an axe/spear). The Chaos Warriors box also comes with a couple of axes & maces/mauls that can be "redeemed" for the Imperium.
http://www.games-workshop.com/gws/catalog/...dId=prod900152a
I also think the DCA have "two power weapons" and the dwarves only have the 1 axe. However, the DCA model itself has one of the models with only 1 power weapon. I also saw some elf fantasy models that were cheaper than DCA and "outside the box" that might work.
Here is a more human DCA option: http://www.games-workshop.com/gws/catalog/...Id=prod1500370a
Fits better with the Dunlending guys.
I made my DCAs from DE Wyches with Pig Iron heads:
http://i40.photobucket.com/albums/e235/galootje/Grey%20Knights/20121204_135248.jpg
As for crusaders:
http://www.ebay.nl/itm/321034092608?ssPage...984.m1497.l2648
What axes did you use?
In 5th I was running mostly DCA and Crusaders for my troops. I ended up using Wyches converted to two ccws, removed all the spikes, deldar symbols, and pointy ears. For my Crusaders I use Easterlings with the =][= added to the sheilds and the helmets shaved down to look normal.
Actually, in the 6th edition rulebook, it references squats as an abhuman race, so you could get away with using dwarves as your crusaders, just be ready to open the rule book to page 405 to show them :D
I'm using chaos dwarfs with axes and shields as my crusaders
