whiteraven17708 Posted December 19, 2012 Share Posted December 19, 2012 So i bought a airbrush set up im using Vallejo game color earth khaki and bonewhite I am using the same primer and I use Windex to thin for both hand paint and airbrush paint yet the colors are significantly different anybody know why? Need some help please this isn't matching Link to comment https://bolterandchainsword.com/topic/268072-airbrushing-help/ Share on other sites More sharing options...
whiteraven17708 Posted December 19, 2012 Author Share Posted December 19, 2012 Sorry mods for the double post please delete one, phone was being slow and i may have been button happy Link to comment https://bolterandchainsword.com/topic/268072-airbrushing-help/#findComment-3265062 Share on other sites More sharing options...
S.k.i.t.t.l.e Posted December 20, 2012 Share Posted December 20, 2012 Are you priming with white and finding that when airbrushing the colours you mentioned, they are a shade or two lighter? Could be because when airbrushing, the paint goes on semi-transparent as it's so thin, and this could be allowing some of your primer to show through. If this is the case, you'll just need to add a couple more layers of paint. As long as you're not blocking out any detail with it, it will be fine. Hope this helps. Link to comment https://bolterandchainsword.com/topic/268072-airbrushing-help/#findComment-3266003 Share on other sites More sharing options...
whiteraven17708 Posted December 22, 2012 Author Share Posted December 22, 2012 Yep that's exactly what it was thanks!! Link to comment https://bolterandchainsword.com/topic/268072-airbrushing-help/#findComment-3267388 Share on other sites More sharing options...
Tamwulf Posted December 22, 2012 Share Posted December 22, 2012 If you are using Windex (or any other medium to thin the paint), you are making the paint more translucent. I.e., thinner. :tu: Not trying to make a joke there, it just came out. What I mean is, you are reducing the amount of color in the paint when you add a medium to it. This seems to be a huge problem with GW paints when I run them through my airbrush. They just don't have the pigment count of other paints out there. This was a pretty big problem for me while trying to paint my Stormtalon with GW Blood Red. It was going on pink. :) Took a lot of layers to bring the color up to something close to a red. Switched over to Reaper MSP Blood Red... no problems. Link to comment https://bolterandchainsword.com/topic/268072-airbrushing-help/#findComment-3267623 Share on other sites More sharing options...
