the emperor is scottish Posted December 23, 2012 Share Posted December 23, 2012 I'm planing on using a contempor pattern dreadnought as a count as furioso dred. However instead of just having the frag cannon attached to him I wanted it look like he was holding it like a am holds a bolter. Problem is I'm having trouble finding something that would look like a giant grenade launcher. Any suggestions? Link to comment https://bolterandchainsword.com/topic/268322-frag-cannon/ Share on other sites More sharing options...
Yosef Hausakluif Posted December 24, 2012 Share Posted December 24, 2012 Might be too small, but I have cut down an IG auto cannon and had it look like a giant grenade launcher, or maybe if you can find it, get the old Inquisitor scale bolter from that range! Link to comment https://bolterandchainsword.com/topic/268322-frag-cannon/#findComment-3268759 Share on other sites More sharing options...
NemFX Posted December 25, 2012 Share Posted December 25, 2012 the ork killa kans have a gun called a lobba. cut the top part off of it, should be just fine. Link to comment https://bolterandchainsword.com/topic/268322-frag-cannon/#findComment-3269952 Share on other sites More sharing options...
W0lfie Posted December 25, 2012 Share Posted December 25, 2012 Or you could shave down an ion cannon, just use the main assembly as your frag launcher. Link to comment https://bolterandchainsword.com/topic/268322-frag-cannon/#findComment-3270113 Share on other sites More sharing options...
the emperor is scottish Posted December 26, 2012 Author Share Posted December 26, 2012 Cheers guys ill have a look at you suggestions. I'm wondering if I could use the actual frag cannon trimed down. Think there's anything from the grey knight walker thingy? Link to comment https://bolterandchainsword.com/topic/268322-frag-cannon/#findComment-3270739 Share on other sites More sharing options...
Pig Of Sparta Posted December 29, 2012 Share Posted December 29, 2012 You might be able to use the Heavy PsyCannon muzzle and a couple of the generic weapon casings from the Dreadknight weapons in addition to some of the Fragment Cannon parts, plasticard, greenstuff etc to make a 'bolter' for a Contemptor. Link to comment https://bolterandchainsword.com/topic/268322-frag-cannon/#findComment-3273588 Share on other sites More sharing options...
