W0lfie Posted December 25, 2012 Share Posted December 25, 2012 Alright, so I am currently assembling Sevrin Loth and his four honour guards, and can't figure out for the life of me how to attack their power axes. The axes are the type of item that have a hand attached to the shaft. In the entire kit, there is not a single arm that ends at the wrist, they all have bolt pistols, are pointing or are meant to cradle the end of a bolter. If anyone has assembled them, can they tell me how they managed to do so? Thanks in advance. Link to comment https://bolterandchainsword.com/topic/268471-how-to-assemble-sevrin-loths-honour-guard/ Share on other sites More sharing options...
Dosjetka Posted December 25, 2012 Share Posted December 25, 2012 Maybe there's a part of the kit missing? I'd find it strange that they didn't include a hand-less option for the axes... Ludovic Link to comment https://bolterandchainsword.com/topic/268471-how-to-assemble-sevrin-loths-honour-guard/#findComment-3270033 Share on other sites More sharing options...
W0lfie Posted December 25, 2012 Author Share Posted December 25, 2012 Maybe there's a part of the kit missing? I'd find it strange that they didn't include a hand-less option for the axes... Ludovic Maybe they want me to chop the hands, like tac marine bolters? Because everything else seems to be there, and the website shows the arm being plastic, not resin...all the plastic bits are from the standard honour guard kit. Link to comment https://bolterandchainsword.com/topic/268471-how-to-assemble-sevrin-loths-honour-guard/#findComment-3270039 Share on other sites More sharing options...
Devolver Posted December 26, 2012 Share Posted December 26, 2012 By the look of the pictures on forgeworld they do like like the hands have been cut so i think thats the way to go. Good luck with it mate there some nice models :) Link to comment https://bolterandchainsword.com/topic/268471-how-to-assemble-sevrin-loths-honour-guard/#findComment-3270348 Share on other sites More sharing options...
Lorenzen Posted December 26, 2012 Share Posted December 26, 2012 Cut the hands off with a sharp blade, same way you cut the grip off bolters to attatch them. nothing is missing its just part of the hobby to cut & shut. Link to comment https://bolterandchainsword.com/topic/268471-how-to-assemble-sevrin-loths-honour-guard/#findComment-3270419 Share on other sites More sharing options...
mactire Posted December 31, 2012 Share Posted December 31, 2012 Just saw this thread and was wondering are loth's shoulder pads separate. Had an idea about using him as a rune priest and would need to change them. Thanks in advance ;) Link to comment https://bolterandchainsword.com/topic/268471-how-to-assemble-sevrin-loths-honour-guard/#findComment-3275615 Share on other sites More sharing options...
pingo Posted January 1, 2013 Share Posted January 1, 2013 Lorenzen is correct; FW models aren't as easy to work with as GW plastic kits (they are supposed to be "advanced", but I prefer take that to mean "requires patience"). However, cutting off plastic marine hands isn't too tricky if you have a nice sharp blade. You can use the straight edge of the "cuff" as a guide. Link to comment https://bolterandchainsword.com/topic/268471-how-to-assemble-sevrin-loths-honour-guard/#findComment-3275653 Share on other sites More sharing options...
W0lfie Posted January 1, 2013 Author Share Posted January 1, 2013 Just saw this thread and was wondering are loth's shoulder pads separate. Had an idea about using him as a rune priest and would need to change them.Thanks in advance :) The shoulder pads were, in fact, separate. Good thing, too, because the forgeworld-assembled sevrin loth had them on the wrong sides, and the red scorps are codex-compliant (his chapter symbol is on the left in that picture; librarians should have it on the right) Link to comment https://bolterandchainsword.com/topic/268471-how-to-assemble-sevrin-loths-honour-guard/#findComment-3275692 Share on other sites More sharing options...
Disruptor_fe404 Posted January 2, 2013 Share Posted January 2, 2013 Uh... I'm fairly certain that Chapter insignia always go on the left on power armour... Link to comment https://bolterandchainsword.com/topic/268471-how-to-assemble-sevrin-loths-honour-guard/#findComment-3276506 Share on other sites More sharing options...
W0lfie Posted January 2, 2013 Author Share Posted January 2, 2013 Uh... I'm fairly certain that Chapter insignia always go on the left on power armour... Not on Librarians, Chaplains, Techmarines, Apothecaries or Deathwatch. Link to comment https://bolterandchainsword.com/topic/268471-how-to-assemble-sevrin-loths-honour-guard/#findComment-3276539 Share on other sites More sharing options...
Peredyne Posted January 2, 2013 Share Posted January 2, 2013 Uh... I'm fairly certain that Chapter insignia always go on the left on power armour... Not on Librarians, Chaplains, Techmarines, Apothecaries or Deathwatch. Actually, W0lfie, you're wrong on that count. The specialists in Codex Chapters wear the Chapter insignia on the left shoulder pad, the same as non-specialists. The only exception to that is if they are wearing Mk 6 armor with the studded shoulder pad. Check the GW main site and look at the specialists. The Deathwatch wear it on the right because they wear the Deathwatch pad on the left. Link to comment https://bolterandchainsword.com/topic/268471-how-to-assemble-sevrin-loths-honour-guard/#findComment-3276549 Share on other sites More sharing options...
mactire Posted January 2, 2013 Share Posted January 2, 2013 Thanks wolfie that wil be easier than hacking them off. Should have also asked is the head seperate from torso or all one piece :tu: Link to comment https://bolterandchainsword.com/topic/268471-how-to-assemble-sevrin-loths-honour-guard/#findComment-3276764 Share on other sites More sharing options...
