Ushtarador Posted December 29, 2012 Share Posted December 29, 2012 Forgot about this version, but I find baal predators better than normal ones for this role ;) Objectively I'd say that the twin assault cannon is better than the autocannon for anti-infantry purposes. The upside to the autocannon is that that variant costs 45 points less. Downside is that its Heavy Support instead of Fast Attack. For a low points game I could be persuaded to the autocannon pred, or if I wasn't using the heavy support slots otherwise (or had several to spare, like in double FoC). I also really like the scouting rule on the Baal to get into a good firing position or hide from some anti-tank pre-first turn. But true, the predator is a very cheap alternative - but the twinlinked assault cannon is a lot stronger than the autocannon if you think about it, against every opponent. Hell, it can even deal with flyers if you have to. Link to comment https://bolterandchainsword.com/topic/268656-predator-annilator/page/2/#findComment-3273791 Share on other sites More sharing options...
Sokhar Posted December 29, 2012 Share Posted December 29, 2012 Agreed, hence why I said I'd definitely only consider the auto/hb predator in a situation where I had limited points or an overabundance of of available FoC slots. The twin assault cannon is better, but is it 45 points better? Perhaps not. But that's usually a moot point because there's rarely situations where I'd want to use the heavy support predator as opposed to Storm Ravens, Vindicators, or Auto-Las Predators instead. Link to comment https://bolterandchainsword.com/topic/268656-predator-annilator/page/2/#findComment-3273807 Share on other sites More sharing options...
dswanick Posted December 29, 2012 Share Posted December 29, 2012 One situation where the Annihilator shines is in Spearhead. A squadron of three Archeotech Annihilators make even Superheavies sweat. The idea of 3X TL 48" S10 AP2 and 6X 48" S10 AP2 shots is terrifying to enemy Armor. Link to comment https://bolterandchainsword.com/topic/268656-predator-annilator/page/2/#findComment-3273812 Share on other sites More sharing options...
Brother apocalyptic Posted December 30, 2012 Share Posted December 30, 2012 I plan of using 2 preds, both with autocannon turrets and Lascannon sponsons, coupled with a vindicator My armoured pool would be those 3 tanks, coupled with 2 baals, and a LR redeemer Link to comment https://bolterandchainsword.com/topic/268656-predator-annilator/page/2/#findComment-3274105 Share on other sites More sharing options...
