MFive Posted January 4, 2013 Share Posted January 4, 2013 sense the wording is so similar, would the Psy-Shock effect of the MS missile effect a squad of psykers only once?(example a strike squad) or every psyker in the squad? example a hit 4 PAGK's would they all suffer a perils or only one? Link to comment https://bolterandchainsword.com/topic/269168-mind-strike-missiles/ Share on other sites More sharing options...
Brother Bobert Posted January 4, 2013 Share Posted January 4, 2013 Mind strike missiles just use the rule psy-shock. Psy-shock says that any psykers hit suffers perils, so they way I've been running it is that if the psyker is under the template the they are hit, the wound may go some where else. If it's covering multiple psykers then they all peril. Even if the "wounds" from the blast are placed on other models. Link to comment https://bolterandchainsword.com/topic/269168-mind-strike-missiles/#findComment-3278638 Share on other sites More sharing options...
Gentlemanloser Posted January 4, 2013 Share Posted January 4, 2013 Units with the 'Brotherhood of Psykers' special rule follow that rule, and would only suffer a single wound from a Mind Strike. Regardless of how many where hit. Link to comment https://bolterandchainsword.com/topic/269168-mind-strike-missiles/#findComment-3278734 Share on other sites More sharing options...
adamv6 Posted January 4, 2013 Share Posted January 4, 2013 +1 for what GL said. Other than that, if you hit a pack of Eldar Warlocks, they all perils :D (I like shutting down Wraithguards this way :cuss) Link to comment https://bolterandchainsword.com/topic/269168-mind-strike-missiles/#findComment-3278755 Share on other sites More sharing options...
jeffersonian000 Posted January 11, 2013 Share Posted January 11, 2013 Did anyone else notice that you can no longer take invul saves for Perils? While our Mind Strike Missiles got tougher in 6th, our entire army just got a tad bit more fragile. Its a good thing only one PAGK will get crushed, as all getting crushed (like Warlocks) would be just a little too much, don't you think? SJ Link to comment https://bolterandchainsword.com/topic/269168-mind-strike-missiles/#findComment-3280337 Share on other sites More sharing options...
