Polythemus Posted January 12, 2013 Share Posted January 12, 2013 Firstlywelcome back everyone from the abyss of the downed site. Two questions: the generic rule for banners states add "1" to assault results if a banner is locked in combat. Does this mean add 1" to assault distance? Second how does everyone view the stubborn rule? When is it beneficial? Seems like its only use is protection from a lost assault, but in that case youll still be fine because of atsknf? What gives? Link to comment Share on other sites More sharing options...
HJL Posted January 12, 2013 Share Posted January 12, 2013 stuborn means we never suffer negative ld modifiers. i cant see many examples of that being bad. +1 to combat resolution isnt much but every little helps. means + 1to the final result of combat. so if you do 4 wounds you count as doing 5 Link to comment Share on other sites More sharing options...
cielaq Posted January 12, 2013 Share Posted January 12, 2013 No, it means, when calculating the results of assault, you add 1 to the number of wounds you have inflicted to determine who has won the assault. Link to comment Share on other sites More sharing options...
Russ Brother 92 Posted January 12, 2013 Share Posted January 12, 2013 No, it means, when calculating the results of assault, you add 1 to the number of wounds you have inflicted to determine who has won the assault. which is exactly what is meant by "when you are calculating the combat result you add one - thus as the frater above said if YOU have done 4 wounds you COUNT-AS doing 5..." Link to comment Share on other sites More sharing options...
Cactus Posted January 12, 2013 Share Posted January 12, 2013 I think HJL and cielaq were posting at the same time brother. Link to comment Share on other sites More sharing options...
Russ Brother 92 Posted January 12, 2013 Share Posted January 12, 2013 In that case I am sorry if my tone was off :/ I shall go and repent in room 42 :) Link to comment Share on other sites More sharing options...
CovertToaster Posted January 12, 2013 Share Posted January 12, 2013 The big thing that polythemus says is "...if a banner is locked in combat" therefore it can never add to assault distance as it would not be locked in combat at that time. Link to comment Share on other sites More sharing options...
Polythemus Posted January 13, 2013 Author Share Posted January 13, 2013 I suppose im just unfamiliar with the term assault result. If it is refering to the counting wounds at the end of combat then i have my answer. But i still cant think of an ability that just reduces your leadership. Do chaos have something like this? Link to comment Share on other sites More sharing options...
HJL Posted January 13, 2013 Share Posted January 13, 2013 you lose combat you minus the number of wounds you lost by and minus that from your ld. it should happen quite a lot in most games. Link to comment Share on other sites More sharing options...
Harleqvin Posted January 13, 2013 Share Posted January 13, 2013 The big thing that polythemus says is "...if a banner is locked in combat" therefore it can never add to assault distance as it would not be locked in combat at that time. He's asking if that's what it does. It's the assault results done at the end of combat he had gotten confused on. To answer his first question as the other shave done above. It doesn't add to distance for charging, just like the guys above have said. It makes your assault result at the end of combat 1 higher than it would be otherwise. i.e. you did 4 wounds and your opponent did 4, normally it would be tie but if you had the banner, you would count as one higher. So your tally is actually 5, so you would win. Link to comment Share on other sites More sharing options...
Excessus Posted January 13, 2013 Share Posted January 13, 2013 Problem is, if you lost the combat you might not want to stick around for more beating. And since the loyalist marines are impossible to destroy when swiping, all stubborn does is hinder them from getting out of a combat they most likely will die from. It also hinders all other things to shoot at the enemy since you are locked in combat against them. I'd say stubborn is thematic, but hardly an advantage in most cases... Link to comment Share on other sites More sharing options...
Brother Amarel Posted January 13, 2013 Share Posted January 13, 2013 d say stubborn is thematic, but hardly an advantage in most cases... I'd say it was a disadvantage, really. Same as Inner Circle granting Fearless rather than ATSKNF. Link to comment Share on other sites More sharing options...
Cactus Posted January 13, 2013 Share Posted January 13, 2013 Tyranid devourers impose a -1 Ld penalty to morale tests caused by their shots and I suspect the Dark Eldar have a number of similar abilities. Stubborn is certainly has its uses and I'll happily take the attitude that my guys in green are unlikely to run from a fight. All the more reason to shoot the enemy first! Link to comment Share on other sites More sharing options...
