Looking for a little advise
Madwolf Shadowmane
I'm slowly working on codex length fluff for my Hounds of the Hunt Chapter. My goal is to eventually print my own codex, but the rules development will wait until the new Space Marine and/or Space Wolves codex comes out. While the rules section will never appear in the Liber, I'm hoping that this is the best section of B n C to post the longer fluff for C&C.
Madwolf
https://bolterandchainsword.com/topic/269393-looking-for-a-little-advise/
I don't think there's any problem with that. I would simply suggest doing it segments, with links in the first post so you can avoid wall o' text.
This would be my response also. If you have a large body of work you already have written up and need it C&C'd, provide it in instalments. So long as the work is contiguous and doesn't get ahead of itself, I don't think going over it piece by piece would be a problem. If things are explained at a later point then pointing that out would be a good idea. Chances are if things are changed early on, it'll have certain ramifications on later material, so bear that in mind. :)
