Emperor's Furor Posted January 13, 2013 Share Posted January 13, 2013 I need to get a vindicator and a whirlwind for my Iron Hands HH army but I was wondering, are the current ones produced by GW ok if I'm staying true to fluff or must I try convert them using the mk II rhino kit or am I over thinking it to much and just use the normal ones either way. Link to comment https://bolterandchainsword.com/topic/269463-tanks-for-hh-armies/ Share on other sites More sharing options...
Raven Angel Posted January 13, 2013 Share Posted January 13, 2013 While I think the 40k ones are ok I'd get some of theses and the vindi and whirlwind sprues and convert some up for that extra fluffy look http://www.forgeworld.co.uk/Warhammer-40000/Space_Marines/Space-Marine-Tanks/MKIC-DEIMOS-PATTERN-RHINO.html Link to comment https://bolterandchainsword.com/topic/269463-tanks-for-hh-armies/#findComment-3281931 Share on other sites More sharing options...
Onisuzume Posted January 13, 2013 Share Posted January 13, 2013 Its an STC vehicle, I doubt there's a way for it to be not suitable. Well, unless its a particular variant that was definitely not around during the heresy. Of course, a lot of variants were around then and subsequently lost before being recovered millenia later. Link to comment https://bolterandchainsword.com/topic/269463-tanks-for-hh-armies/#findComment-3281980 Share on other sites More sharing options...
Emperor's Furor Posted January 13, 2013 Author Share Posted January 13, 2013 I got some vouchers for christmas about £30 worth so I was going to get a part of my army that's not really needed from FW, problem is it appears just about everything is from there. I suppose I could get one then convert it into the original mk with plasticard? Link to comment https://bolterandchainsword.com/topic/269463-tanks-for-hh-armies/#findComment-3282083 Share on other sites More sharing options...
AllHailTheMachine Posted January 13, 2013 Share Posted January 13, 2013 They should be ok. The demios pattern Rhino is only featured in forgeworlds books as it is the most popular pattern of rhino in use at the time of the heresy. As the imperium rarely invents anything the standard GW rhino hull represents an alternative pattern to the demios that was most likely in use at the time, just nit in the same numbers a.s the demios. Â I'm going to be using standard GW vindicators in my army for just this reason. Though I am quite tempted to convert them a bit adding more rivets for example to make them look a bit.more archaic. Link to comment https://bolterandchainsword.com/topic/269463-tanks-for-hh-armies/#findComment-3282221 Share on other sites More sharing options...
Emperor's Furor Posted January 13, 2013 Author Share Posted January 13, 2013 I found the original Vindicator on ebay, so I've gone for that, it has the original rhino chassis etc with the guy "waving" lol. Link to comment https://bolterandchainsword.com/topic/269463-tanks-for-hh-armies/#findComment-3282227 Share on other sites More sharing options...
DuskRaider Posted January 14, 2013 Share Posted January 14, 2013 The Rhino that we're used to is actually the Mars Pattern. It would have also been in abundance at the time of the Great Crusade / Horus Heresy, as I'm sure there were other patterns in use as well. Even looking at the products that FW offers, you'll see they sell Pre-Heresy Rhino doors and front armor for the Mk. IIC, so it's fine. You could also make an amalgam of the two as a completely different pattern or field repairs. Link to comment https://bolterandchainsword.com/topic/269463-tanks-for-hh-armies/#findComment-3283390 Share on other sites More sharing options...
Elazar The Glorified Posted January 14, 2013 Share Posted January 14, 2013 There's at least 1 plastic GW Rhino in the Betrayal book so I'm quite happy using them in my army :) Link to comment https://bolterandchainsword.com/topic/269463-tanks-for-hh-armies/#findComment-3283562 Share on other sites More sharing options...
Gamanos Posted January 16, 2013 Share Posted January 16, 2013 I believe I'm somewhat lucky being an IF player. By the time they saw combat at Terra, they'ed raided Mars for the new patterns of armor, both personal and vehicular(Mechanicum). So I would say the BA, WS and IF can get away with it as loyalists using GW's 40k range while the Traitors can probably get away with it too as they received constant new tech in lieu of Horus redirecting it from loyal legions. Link to comment https://bolterandchainsword.com/topic/269463-tanks-for-hh-armies/#findComment-3285176 Share on other sites More sharing options...
SillyDreadnought Posted January 17, 2013 Share Posted January 17, 2013 Go right ahead and use the plastic kits for the more mundane and utilitarian vehicles in your army. Infact, the Land Raider Phobos is the standard plastic kit available. Go for it! Link to comment https://bolterandchainsword.com/topic/269463-tanks-for-hh-armies/#findComment-3287653 Share on other sites More sharing options...
